code question guys..need some help
Old Oct 7, 2007 | 09:05 AM
SilverBullit02's Avatar
SilverBullit02
Default code question guys..need some help
I know how to bring up the codes on my DIC, and have a list of what the codes mean. Here's my problem. On occassion, I get a check engine light. I bring up the codes and it runs through all of them. There are a few "H" codes (history) which I'm not concerened about. When it gets to the PCM portion, it shows "no codes". When I go to the manual portion the PCM shows "2 codes"????? How do I pull what those 2 codes are??? I can reset and clear the "2 codes", but it comes back with the check engine light a few days later.
Thanks........Jim
Old Oct 7, 2007 | 10:18 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Once in Manual mode I believe the #4 OPTIONS button will take you to each Module and then while in each module I believe the #2 Gages and #3 Trip buttons will move you forward and back through each modules codes.
I have not done this in a long time, so I am going off my memory (and that's not all that great )
