Weird windshield washer pump problem?
Old Oct 7, 2007 | 07:03 PM
chpmnsws6's Avatar
chpmnsws6
Default Weird windshield washer pump problem?
The pump is VERY weak when using the stock button, but works great when you jump the pump (wires from battery to pump). It also works great when you jump the positive side of the battery to the pump, so I know it is not a grounding issue. Any idea what can cause it? It starts with 12 volts and ends up going to nothing.
Old Oct 8, 2007 | 06:22 AM
vettelover84's Avatar
vettelover84
loose connection?
Old Oct 11, 2007 | 02:45 AM
chpmnsws6's Avatar
chpmnsws6
When you check voltage with the DMM, It shows volatage going from 12.6 volts at the beginning to nearly 5-6 volts after a few seconds, and then going to nothing.
Old Oct 17, 2007 | 04:44 PM
chpmnsws6's Avatar
chpmnsws6
Anyone?
To Weird windshield washer pump problem?
