[Z06] MAF does not have screen?
it is a delphi unit. is it missing the screen?
anyone have a picture of a stock maf on a 2002 Z06? please post.
eddie
I'll take Z06's for $500 Alex...
I always take off MAF screens. If nothing else, it's a good time.
but you knew that already, of course, and just wanted to see if anyone else knows anything about cars and engines other than what you tell them.
Take a look at this thread .... and note people like Mike Mercury ... who has been doing Corvette work for YEARS recommend NOT to pull the screen ....
Look at the experience level of the people posting replies #4, 10, 15, 25, 28, etc .......
http://forums.corvetteforum.com/show...ght=MAF+screen
It is not just me recommending not to remove the screen .....
goes to show that tuning and complete engine package are most important, not just throwing parts at an engine.
still, i think it is worth removing the screen, and that's what i did.
Sorry I couldn't resist the open shot
The PCM is programmed for a "stock" engine .... once you move outside that range, the PCM is either gonna throw codes
or try and "compensate" for the changes ... which means the changes are negated.I think we're both on the same page ... no need to worry about buying Higgs Boson a beer ....
You see, what I did not say in that thread is that I crashed cars with different varieties of active handling. I have also saved a ton of near crashes without it. When it starts kicking in and removing power and tapping different brakes when you are trying to work the gas and steering wheel it is BAD. Very different from this thread, my good man.
i base the justification of MAF screen removal on the following:
1) MAF consists of heated filament elements ("wires" on CF, most commonly) that measure airflow based on how much they are cooled by the passing air, taking into account the measured ambient temp and barometric pressure
2) incoming airflow in C5 inlet tracts is primarily laminar, vastly reducing the need for a screen, as evidenced by 2002+ GM factory removal of such
3) MAF screen removal may allow slightly increased air flow over MAF wires, which will cool them more, which tells the PCM that more air is incoming, all within range of stock air/fuel tables
4) PCM adjusts fuel OR since PCM is tuned conservatively rich at higher engine speeds and throttle position from the factory, increased air leans out the mixture a bit, allowing greater power output
correct me where i am wrong.
