Sirius Antenna
Old Oct 10, 2007 | 08:44 PM
chrisorris24's Avatar
chrisorris24
Default Sirius Antenna
Where should i mount my magnetic Sirius antenna on our plastic c5's
Old Oct 10, 2007 | 08:50 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
bouble adhesive tape on top center of the hatch glass .
Old Oct 10, 2007 | 08:54 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Inside the rear fascia.
Old Oct 10, 2007 | 09:13 PM
1dog's Avatar
1dog
I just throw mine up on the dash and it works just fine.
Old Oct 10, 2007 | 09:18 PM
wanttospeed's Avatar
wanttospeed
I put my inside my headliner out of sight. The roof is fiberglass, so no obstructions from metal, it comes in clear.
Old Oct 10, 2007 | 09:45 PM
jrose7004's Avatar
jrose7004
Mine is in the corner on the dash on the passenger side.
Old Oct 10, 2007 | 09:53 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
I tried under rear facia but reception was horrible! I really didnt want to but I put it on my hatch window and it comes in great. The trick is you must have it horizontal for best reception.
Old Oct 10, 2007 | 10:00 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
middle forward edge of the trunk...
Old Oct 10, 2007 | 10:23 PM
MAC5's Avatar
MAC5
Under rear facia. Made 90 degree bracket that mounts to the rear tub. Antenna is about 1/2 inch under the rear facia.
Old Oct 11, 2007 | 07:02 AM
RSchleder's Avatar
RSchleder
Default DASH it
I have a 2000 vert and I use a dash pad to protect the dash from the sun. I put a small piece of velcro on the back of the antenna and it sticks to the dash pad and picks up the signal very well. Just ran the wire UNDER the dash pad to the radio and WALLA, it works great and it's eccentually hidden! Ron
Old Oct 11, 2007 | 07:05 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I mounted mine up on the dash in the middle of it tucked the wire along the window in the crack and it came out perfect!
Use a piece of double sided tape or a small piece of Velcro!
Thanks,Matt
Old Oct 11, 2007 | 07:39 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
My reception sucked on the dash. I moved mine out by the window wipers. No one has even noticed it.
Old Oct 11, 2007 | 09:28 AM
chris308's Avatar
chris308
tried the rear facia spot but reception was choppy at best. moved it to the dash, driver side corner w/velcro.
Old Oct 11, 2007 | 12:08 PM
NEVERL8C5's Avatar
NEVERL8C5
I used 3m automotive attachment tape and mounted it in the rear fascia right above the left inside tailight. Never have had a reception problem after 2 years and still rockin.Had to replace the speakers a couple of times but that is a volume issue.
P.S. I actually know when I am in the garage far enough for the door to close as the radio goes to acquiring signal.
Old Oct 11, 2007 | 12:18 PM
LoneStarFRC's Avatar
LoneStarFRC
Same here. Good reception.
Old Oct 11, 2007 | 12:25 PM
Vette-kid's Avatar
Vette-kid
My bracket mounts to the rear frame and pressure fits at the top. I think it also help reception to have the antenna near the corner not the center. I get great reception.
Old Oct 12, 2007 | 12:19 PM
Shinobi'sZ's Avatar
Shinobi'sZ
On the outside windshield washer tray?
Mine is currently mounted up front on the dash by the IR sensor (exhause vents). The stereo shop had a square black piece of magnetic tape (sticky on one side, magnet on the other). I just stuck it up there and ran the wires along the inside of the windshield in front of the dash pad....mine is also a Nav unit so it has two wires.
Old Oct 14, 2007 | 08:44 PM
RFS-Z06's Avatar
RFS-Z06
Mounted mine on rear trunk lid... Used a little silicone to hold it in place Looks like it belongs there...
To Sirius Antenna
