Guys w/ headers
Old Oct 12, 2007 | 10:58 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
The overall biggest difference is in when you get in the throttle hard.
Old Oct 12, 2007 | 11:07 AM
nwdanner's Avatar
nwdanner
I bought and installed LG Pro LTs w/cats and Quad Borla Stingers over 2 years ago. I've had ZERO problems with the setup (no leaks, rattles, etc) and get TONS of compliments; best mod I've done yet! The sound is eargasmic! There is a little drone around 1700rpm but that's the Borla's and not the LTs -- nothing a down-shift won't fix.
After professional PCM dyno tuning my car gained ~35rwhp/30rwtq.
Next up, ECS Novi kit...
Old Oct 12, 2007 | 11:11 AM
jpc0011's Avatar
jpc0011
So at low rpm's like 20 mph thru a residential street will I be waking the neighbors. I just dont obnoxius loud.
Old Oct 12, 2007 | 11:19 AM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
^^^ It will be loud on startup, mine is but I do have a decent sized cam. Once your rolling and not in the throttle in the situation you mentioned, it won't be too bad. I can cruise through a neighborhood in second and its fine. FrankTank said it well in post 21
Old Oct 12, 2007 | 11:22 AM
nwdanner's Avatar
nwdanner
At idle and low RPMs (1500 or less) the car emits a very low rumble. I have a 6-speed so I can easily control the volume. I often leave my house (as quietly as possible) around ~6:30am and I've NEVER had a compliant from neighbors. I don't think an A4 would be much different at low speeds.
The catalytic converters make a big difference in my setup (LG Pro LTs & Borla Stingers) -- without cats the noise is definitely louder and more harsh sounding. If you decide to go cat-less then I would go with something closer to the Z06 TI cat-back. Given the high-flow cats only rob ~5hp I'd put them on if I were you. Not only will it smell better, but it'll sound cleaner too!
Old Oct 12, 2007 | 11:32 AM
jpc0011's Avatar
jpc0011
Thanks. This is the type of info I am looking for. I relly don't know anyone who owns a vet w/ headers.
I want more sound at low rpm as I think even w/ the pace cars the exhaust is fairly mild and not loud sound unless I am nailing it.
Old Oct 12, 2007 | 11:38 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
AR and LG's are great headers for C5's
I personally like the LG's! ! and have them on my car!
Old Oct 12, 2007 | 12:12 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
that is the nice thing about corsa's is with headers you can cruise by and they are faily quiet, won't wake the neighbors unless you hammer on the throttle... but yea upon cold start up it can be a little loud until it idles down a bit.
Old Oct 12, 2007 | 12:33 PM
jpc0011's Avatar
jpc0011
My corsa's are always loud anyway at start up. As soon as they warm up its amazing how the sound level drops.
Thanks for all the great feedback. I will going to ECS for install so I pretty pumped
Old Oct 12, 2007 | 01:06 PM
sdnet's Avatar
sdnet
I will be adding either ARH or LG street series soon to my Corsa Pace car's. Just wondering if any difference in the sound? Not looking for too loud. Thanks
I just had Kooks LT headers installed a couple months ago, and yes, you'll definitely notice a difference. With mine, I can really hear the difference over about 3,000 RPMs. If I step on it even a little, it'll scream...and I have GHL Magnum straight-through mufflers, so my car wasn't exactly quiet to begin with.
Old Oct 12, 2007 | 01:20 PM
corvettebob1's Avatar
corvettebob1
Kooks 1 3/4" with 3" high flow cats and 3" exhaust back to B&B Route 66 mufflers.
Nice growl at low speeds and part throttle, no drone at highway speeds and you can carry on a conversation without raising your voice.
WOT is pretty loud but still not obnoxious, it even passed the wife test!
Old Oct 12, 2007 | 01:36 PM
jpc0011's Avatar
jpc0011
The wife test is important! Thats the first thing mine asked. It's not going to be too loud is it?
Old Oct 12, 2007 | 01:55 PM
  #33
peter pan's Avatar
peter pan
Life Time NCM #2196
Here is a sound clip from my setup
Old Oct 12, 2007 | 03:12 PM
  #34
2003vert's Avatar
2003vert
Originally Posted by steve8
The sound clips are good, but you should hear them in person. This is not a decision you want to make, and then regret.
Steve8 is exactly correct if you are in any way not sure find someone that has them.
Old Oct 12, 2007 | 05:32 PM
  #35
jpc0011's Avatar
jpc0011
Peter Pan that sounds insane. A bit too loud for me. You do have it heavily modded thou.
Old Oct 12, 2007 | 05:45 PM
  #36
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
Originally Posted by 81c3
This is what you want. Its not too quiet or too loud. At idle its a bit deeper & under throttle it gets progressivly louder with rpm. With the Ti's I find it almost to be an exotic sound when the rpms are up. Theres no drone in the cabin at any speed. You wont sound like a school boy in a jacked up pick-up with glass packs....and it will be a big difference over stock both in sound quality & performance gains.
Good Luck!
Old Oct 15, 2007 | 03:43 PM
  #37
Dennis B's Avatar
Dennis B
8th Gear
Just my opinion.......have an 05 Vert.....put GHl's on.....absolutely LOVED them.....PERFECT!!! Then did AR's with HFlow Cats.... a Vararam and a tune........very disappointed in the sound. Really nasty drone in 6th or at 1600 RPM. Power is beyond belief......gained 47.3 RWHP......but I'd trade the HP for the sound I had before the AR's
