Exhaust / Headers
Old Oct 13, 2007 | 02:37 AM
rskeller's Avatar
rskeller
Default Exhaust / Headers
Is it possible to keep the same exhaust and just put headers on it to add some growl. If not I was going to put on the MagnaFlow with the X-Pipe. Also what would be the difference if you were to only put headers on it? Changeing the exhaust does that increase the HorsePower. PS: you guys are great on here
Old Oct 13, 2007 | 02:44 AM
Showdown's Avatar
Showdown
Old Oct 13, 2007 | 06:00 AM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
I am assuming that you currently have a stock exhaust?
If that is the case, be advised that bolting on headers is not as simple as it seems. LTs will require new and smaller cats so they fit under the car and new cat-back system.
There are brackets wires and hoses that close to the stock system that have to be modified or moved to protect them from the increased bulk and heat of the LT headers.
In other words, you will NOT be able to run a stock cat-back with LT headers. If I am wrong, (I doubt it ) I am sure others will chime in with their take
EDIT: I assume you are wanting LT headers and not shorties.
Old Oct 13, 2007 | 09:00 AM
B-Vette's Avatar
B-Vette
You can get a set of Kook's with stock cat adaptors if you wish. Lingenfelter sells them as well as the Dynatech's if you would like to compare the two systems. The Kook's are a long tube system.
Old Oct 13, 2007 | 09:08 AM
81c3's Avatar
81c3
[QUOTE=Chemdawg99
Yes you can. You can buy or build cat adapters. Also, with longtubes & an X-pipe you can add hi-flow cats to stay legal & still run the stock tailpipes & mufflers.
Old Oct 13, 2007 | 10:32 AM
Higgs's Avatar
Higgs
Actually I installed my LG long tubes/X pipe setup and ran it with the stock exhaust for a little while (while I was shopping for a cat back).
Many LT Headers come with an Xpipe arrangement to take the exhaust back to the "cat back" connection point. What's a little trickier is getting Long tube headers-only arrangements to interface with a factory H pipe... involves cutting/welding generally.
Old Oct 13, 2007 | 11:45 AM
Chemdawg99's Avatar
Chemdawg99
Okay,
here's the Chemdawg's philosophy on mods, especially extensive ones like headers. There are quality headers out there (LG is VERY good). IMHO, you are not going to get a clean install (DIY or professional) keeping the stock cat-back. You are not taking advantage of the full potential of the headers. This is taking the cheap way out, and I promise you that you will pay now or pay later. Just because you can do something, doesn't mean you should. If you are going to go with headers, change the rest of the system along with it if you want OPTIMAL results
Old Oct 13, 2007 | 11:53 AM
Higgs's Avatar
Higgs
Okay,
Yep. Factory mufflers flow pretty well but I wouldn't want to try to blend a long tube header setup into a factory exhaust as my "permanent" solution.
Old Oct 13, 2007 | 05:26 PM
B-Vette's Avatar
B-Vette
Let's go back to the first question on this thread by "rskeller." "Is it possible to keep the same exhaust and just put on headers..." YES!!!!!!
Long tube Kook's (for example), can be ordered with factory adapters - all premade by Kook. There is no need for custom work at all. The majority of your horsepower doesn't come from your exhaust pipes, it comes from the headers. Also, the only difference in horsepower between stock cats and aftermarket is 5 HP. You'd be hard pressed to notice any difference unless it's on a dyno. Why change something that isn't broken?
The beauty of the Kook setup for the C5 is that you can individually buy the components to change the cats, x-pipe, etc, later if you wish. Money maybe one of the chief reason's for not wanting to buy a complete system off the get go. Maybe the loudness, noise or drone of a complete header system and aftermarket exhaust may be another.
You will add noticeable "growl" to a stock muffler system with a long tube setup and pickup horsepower.
Old Oct 13, 2007 | 07:00 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Alot of people that go with headers and keep the stock exhaust will (including myself) will use the long tubes, cats and mid-pipes. They will bolt up to the rear section of the stock exhaust. There won't be a big change in the sound during normal driving. You'll notice that it might be a little deeper but not that much. The sound becomes more aggressive when you lay into the throttle. The stock exhaust will come to life a little more at that point.
Long tubes will usually take the sound of an aftermarket exhaust and kick that up a few notches too.
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE
E-MAIL - tbyrne@tbyrne.com
Supercharged "Z06 Body" 2005 Convertible For Sale (car pictured to the left)
Old Oct 14, 2007 | 01:02 AM
Chemdawg99's Avatar
Chemdawg99
I am not disputing what you are saying here, but if you are going to replace the stock manifolds with LT headers, IMHO, you should go all the way and replace the whole system.
Old Oct 14, 2007 | 01:27 AM
rskeller's Avatar
rskeller
So if I change the exhaust to a magnaflow system do you put headers on that also with the x-pipe? ( Corvette Virgin)
Old Oct 14, 2007 | 01:32 AM
Chemdawg99's Avatar
Chemdawg99
I would recommend using an H-pipe rather than a X-pipe, but with good fabrication you can go with a magnaflow/LT/x-pipe combo. It will probably cost you more though.
Old Oct 14, 2007 | 10:38 AM
fdxpilot's Avatar
fdxpilot
Okay,
Well, I'm glad you have a philosophy. If you knew what you were talking about, it might even be useful.
Almost every name-brand LT header (LG, Kooks, Dynatech, etc) comes primarily as a full system including headers, off-road pipes or hi-flow cats, and an X-pipe. The system almost always terminates in the same position as the stock system, allowing the use of the stock (or any other) catback. As for power, most catbacks will get you maybe 5-10 HP, so running with the stock system is not a horrible sin. When I had my LTs installed, the techs at LG told me that my stock cat-back was fine, and an aftermarket one might gain me 5 HP.
You can get LTs with adapters to attach to the stock sytem around the cats, but they usually require some welding and fabrication. Also, if the primaries are long enough (like LGs) the collectors end right about in the stock Cat location, making hookups to the stock midpipes a problem and require ditching the cats.
To Exhaust / Headers
