Fiberglass and Cold
Does anyone know if this is true or just something that happened with older cars before the wonders of modern technology? I ask because I am moving to NC soon and am hoping for year round driving. Thanks
PS: Are you sure that warning was not concerning the tires rather than the fiberglass?
C5s are primarily made from Sheet Molded Composite/Compound (SMC). SMC is a form of fiberglass.
From http://manufacturing-fabrication.glo...27§ionid=1
Sheet molding compound (SMC) is a process in which a layer of fiberglass material is sandwiched between 2 layers of thermoset polyester resin and extruded into flat sheets. The sheets are pressed into final form by heated molds.
http://www.corvetteactioncenter.com/tech/c5/smc.html
2000 Chevrolet/Geo Corvette
Plastic Identification and Refinishing Systems
Identifying Symbol - Old Symbol in ( )'s
Chemical Composition or Plastic Family Name
Typical Area(s) Where Part is Used
Examples of Common/Trade Names
Type of Plastic
ABS
Acrylonitrile/ Butadiene-Styrene
Armrest Support, Console, IPC, Steering Column Bracket/Jacket, Trim Molding
ABS, Absafil, Magnum, Cycolac, Dyel, Kralastic, Lustran
Thermoplastic
ABS + PC
Acrylonitrile/ Butadiene-Styrene + Polycarbonate
Instrument Panel, IPC
Bayblend, Cycoloy, KHA, Pulse
Rigid
ABS/PVC
ABS/Vinyl (Soft)
Head Rest Cover, Instrument Panel Pad, Trim Molding/Panel
ABS Vinyl
Flexible, Vinyl
EPDM
Ethylene Propylene Diene Monomer
Body Panel, Bumper Impact Strip
EPDM, Nordel
Rigid
EVA (EVAC)
Ethylene/Vinyl Acetate
Head Rest Cover, Misc Soft Trim
Elvax, Microthane
Flexible
PA
Polyamide
Headlamp Bezels, Quarter Panel Extensions, Exterior Finish Trim Panels
Nylon, Capron, Zytel, Rilsan, minion, Vydyne, Welland
Rigid
PA, PAG, PAGG
Polyamide
Exterior Finish Trim Panel, Headlamp Bezel, Quarter Panel Extension
Capron, Minlon, Nylon, Rilsan, Vydyne, Wellamid, Zytel
Rigid, Thermoset
PA + PPE
Polymide + Polypheneylene Ether
Exterior Trim, Fender
GTX
Rigid, Thermoset
PBT + TEEE (PBTP + EEBC)
Polybutylene, Terephthalate + Ether, Ester Block Compound
Fascia, Rocker Panel Molding
Bexloy M
Rigid
PC
Polycarbonate
Interior Rigid/Hard Trim Panel, Valance Panel
Calibre, Lexan, Merlon, Makrolon
Rigid, Thermoset
PC + PETP
Polycarbonate + Polybutylene, Terephthalate
Bumper Fascia
Macroblend, Valox, Xenoy
Flexible, Thermoset
PE
Polyethylene
Fuel Tank Shield, Inner Fender Panel, Interior Trim Panel, Seat Belt Cover, Spoiler, Valance
Alathon, Dylan, Foriflex, Hi-fax, Hosalen, Marlex, Paxon
Rigid, Thermoplastic
PF
Phenol Formaldehyde
Ashtray
Amberol, Bakelite, Durez, Genal, Phenolic, Plyophen, Resinox
Rigid, Thermoset
PP
Polypropylene
Bumper Fascia, Cowl Panel, Deflector Panel, Door Panel, Inner Fender, Interior Molding, Kick Panel, Load Floor, Radiator Shroud, Wheel Cover
Azdel, Daplen, Escorene, Marlex, Novolen, Oleflo, Profax, Tenite
Flexible, Thermoplastic
PPE (PPO)
Polyphenylene Ether
Bezels, Chromed Plastic, Headlamp Door, Ornaments
Noryl, Oleflo, Prevex
Rigid, Thermoset
PS
Polystyrene
Dash Panel, Door Panel
Durathon, Dylan, Lustrex, Polystyrol, Styron
Flexible, Soft
PUR
Polyurethane, Thermoset (Unsaturated)
Bumper Fascia, Filler Panel, Front/Rear Body Panel, Pickup Box
Bayflex, Castethane, RIM, RRIM, SRIM
Thermoset
PVC
Polyvinyl Chloride (Vinyl)
Interior Soft Trim, I/P Skins, Roof Cover
Geon, Pliovic, Unichem, Vinoflex, Vinyl, Vinylite
Flexible, Vinyl
SAN (SA)
Styrene Acrylonitrite
Center Console, Glove Box Door, Interior Trim Panel
Foracryl, Lustran, Tyril
Rigid
TEO (EP, EPM, TPO)
Ethylene/Propylene (Rubber)
Air Dam, Bumper Fascia, Valance Panel
EPI, EPII, TPO, TPR (Thermoplastic Rubber)
TPO
Thermal Plastic Oletin
Bumper Covers
TPO
TPU (TPUR)
Polyurethane, Polyolefin
Bumper Fascia, Gravel Deflector, Soft Filler Panel, Window Molding
Estane, Pellethane, Roylar, Toxin
UP
Polyester/Thermoset
Air Scoop, Air Spoiler, Fascia Extension, Hood, Instrument Housing, Rear Compartment Lid, Roof, Ventilation Grid
Fiberglass, Premi-glass, Selectron, SMC, Vibrinmat
Rigid, Thermoset
