Spark plug change not so bad.
Old Oct 13, 2007 | 01:56 PM
TomT's Avatar
TomT
Default Spark plug change not so bad.
I have read the tales of woe and bloody knuckles while changing the spark plugs, and have dreaded the task. So finally, today, after 38k miles and 6 years since new, I changed them and it wasn't bad at all. Here are the 3 things that made the change very easy.
1. I rotated each plug wire a quarter turn at the plug to break the seal. Then, they came off easily.
2. I removed the left side plastic coil cover (aka valve cover). Only after getting my one and only cut.
3. I removed the plumbing between the second and third cylinder on the drivers side, and set it up out of the way. Only 2 bolts here, but it made the rear 2 plugs on the drivers side a breeze.
Total time 1 hour. Not too bad.
Old Oct 13, 2007 | 02:52 PM
csexton's Avatar
csexton
Good job.
Chuck
Old Oct 13, 2007 | 03:37 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
good tips
Old Oct 13, 2007 | 03:41 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
The "double swivel" makes the job easier. Sears has them for under 10 bucks.
Old Oct 13, 2007 | 04:56 PM
moserbe's Avatar
moserbe
Thanks for the tips.
Old Oct 13, 2007 | 05:01 PM
TimeCr0ss's Avatar
TimeCr0ss
This post is getting bookmarked. I'm sure I'll be doing this soon...
Old Oct 13, 2007 | 06:47 PM
Autoworker's Avatar
Autoworker
I'm curious to see if you were missing any of the platnum pucks on the electrodes of the plugs. I changed mine at 50,000 and had several missing. Also the gap was pretty big on most of them if I remember.
Old Oct 13, 2007 | 06:51 PM
z06Bigbird's Avatar
z06Bigbird
I thought these plugs were good for 100k!
Old Oct 13, 2007 | 06:53 PM
mhdi22's Avatar
mhdi22
Good tips.............thanks.
Old Oct 13, 2007 | 08:53 PM
TomT's Avatar
TomT
No missing pucks. Gaps were about 60 thou.
I put Bosch +4 plugs in. No gapping necessary. Will see how they last.
Old Oct 13, 2007 | 09:20 PM
Congrats on getting them changed. Good tips you mention.
Old Oct 13, 2007 | 09:27 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
They are.
To Spark plug change not so bad.
