Creaking suspension
Old Oct 14, 2007 | 12:32 PM
z28flash's Avatar
z28flash
Default Creaking suspension
I added Addco anti-sway bars a few weeks back, and last week did about a one lowering on the stock suspension. I have a lot of creaks and groans now, mostly in the rear end. I did notice that the new urethane bushings for the rear sway bar seemed a little large for the bar, meaning there was a little space around them when I put them on. However, after they were tightened it seemed better. Any ideas? I have thought of removing the bushings and replacing them with the originals, but not really sure that is a solution.
Old Oct 16, 2007 | 02:37 AM
romeorn's Avatar
romeorn
I would also like some idea as to what could be causing this noise. My 2004 Coupe (27k miles) also creaks both front and rear when I make slow turns into my neighborhood (looking out for the little kids). I would say it sounds as is someone in rolling around in a fold-away springs/coils bed. This noise has been going on for about a month, on and off. I was thinking it was the bushings or a need for new shocks. Sorry to leech off of you intial posting but... anyone with any ideas?
Old Oct 16, 2007 | 07:06 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
shoot some dry lube in the crevices around the bushing and see if that helps......
Old Oct 16, 2007 | 07:34 AM
Tigershark3's Avatar
Tigershark3
your new bushing should have come w/ some sort of vasoline like lubricant. I recently changed my OEM bushings to poly and my squeaks went away. $.02 deposited
Old Oct 16, 2007 | 10:53 AM
z28flash's Avatar
z28flash
With the Addco sway bars I did get new poly bushings....but I'll try some lube on them, maybe a shot of silicone to start. I was also wondering if lowering the car on the stock shocks could cause it. I'm planning on putting on Bilstein Sports in the near future, so will find out a little more...
Romeorn, sounds like the same problem. I only hear it during slow speeds, but then again maybe at higher speeds I cannot hear it over the road/engine/stereo noise, lol!
Ah, the mysteries and enjoyments of working on your Vette, hehe!!!
Old Oct 16, 2007 | 11:29 AM
timemender's Avatar
timemender
In my personal experience spraying silicone does little to help for any length of time.
Try some lube with Teflon it will work better than silicone. However, the best method is to take it apart an put a waterproof grease directly on the bushing contact area.
Actually, I live with the squeak on one of my cars (my driver) for two reasons; 1 - Don’t feel like tearing the suspension apart; and 2 – It only creaks going over speed bumps and the like at low speeds. (Can’t hear it at normal driving speeds)
Old Oct 16, 2007 | 11:37 AM
TimeCr0ss's Avatar
TimeCr0ss
I have the same exact problem on my '00 coupe. And as far as I know, my suspension is all stock. I don't know how it sounds on the outside, but it is very audible on the inside. I get this noise from both my front and rear suspension.
Old Oct 16, 2007 | 12:15 PM
rare-72's Avatar
rare-72
Same issue. Low speed squeak over bumps front and rear. I replaced the sway bar bushings, no difference. Can you buy new shock bushings? My shocks are fine, but I think the dry climate kills bushings here.
Old Oct 16, 2007 | 01:11 PM
z28flash's Avatar
z28flash
Think tomorrow I'll try some sort of grease lubricant....doesn't take that long to jack it up and unbolt the brackets. I'll let ya know! It's just a little annoying, but of course, turn up the tunes and you can't hear it, lol! I put a subwoofer in the back, best thing I've done...well, except for maybe the new wheels....or the vararam....or Lloyd's carpets...or the exhaust....or my stripes....LOL...it just goes on and on!!!
Old Oct 16, 2007 | 01:39 PM
shannanl's Avatar
shannanl
I lowered mine on the stock bolts about a month ago and have had this since then.
Old Oct 16, 2007 | 02:23 PM
BigSexy181971's Avatar
BigSexy181971
Default Same issue here
The back squeeks over speed bumps. Let us know, I would like to get rid of the squeeks too.
Old Oct 16, 2007 | 03:38 PM
wkasak_07Z06's Avatar
wkasak_07Z06
My 98 used to squeak like an ol' bed when going over speed bumps...
I removed the sway bar bushings (stock) front and rear...greased the crap out of them and re-installed. No more squeaks...all gone. I used regular automotive grease...worked like a charm.
Old Oct 16, 2007 | 04:19 PM
romeorn's Avatar
romeorn
The exact complaints you all have posted is exactly how and when I hear the most squeaking... and you are right at high speeds - not a problem... maybe I need to keep the mph high? I will try your recommendations... thanks guys!!!
Old Oct 16, 2007 | 04:32 PM
TimeCr0ss's Avatar
TimeCr0ss
Well, that's hard to do when cruising the city with a nice lady in shotgun. It is a wee bit embarrassing, but nothing I couldn't deal with.
Old Oct 16, 2007 | 04:46 PM
Oldvetter's Avatar
Oldvetter
I used urethane bushings from Eckler's, they came with a special grease.
When lubing these bushings, lube all surfaces that touch metal, including the metal bushing holder, not just the inside diameter that touches the swaybar. I would use dielectric silicone grease, but other grease may work.
Old Oct 17, 2007 | 11:45 AM
z28flash's Avatar
z28flash
Nice tip for lubing both the inner and outer surfaces. Tonight I'll pull the bushings and do that, then tomorrow see how it sounds. Seems like I had some noise also from the front right, but I'm going to check to make sure I lowered them all the way...the front seems alittle higher than the rear.
Old Oct 18, 2007 | 10:24 AM
z28flash's Avatar
z28flash
Default still groaning....
Well, just to update......I removed and placed grease on both the rear and front sway bar bushings, and sprayed some silicone on the new linkage connectors. Retightened all my lugs...pretty much still have some of the same sound...
I am thinking that since doing the lowering, something has not settled...or the shock is making some noise, since this all happened after I did the stock shock lowering. Mostly seems to be out of the right front area now.
I will say the ride seems a little improved, so the greasing certainly did not hurt, and may have corrected a few of the annoying noises, since the rear is quieter now. So I can't say it's fixed, just a little better.
When I get a chance to put on new shocks, I'll try to remember to let everyone know if that resolves the mystery!
Old Sep 11, 2008 | 05:46 PM
Trog's Avatar
Trog
When you lower a car (any car) you have changed the normal ride position of the actually suspension attachment points. When first installed, the main bolts are tightened at NORMAL ride height. The stock suspension bushings (rubber) do not rotate around the inner bushings, they "stretch". What you need to do is mark the alignment settings, loosen the A-arm bolts and then with the car at normal ride height, retighten those bolts. That puts the stock bushings in a neutral positions, now when the suspension moves a little bit (either way up/down) the rubber can stretch. It it is already stretched from you lowering it, now when the suspension moves it is having to stretch even more, making a noise.
Nylon bushings don't work that way. The bushing actually rotates around the inner metal bushing. Which results in less deflection of the suspension during movement, better response & more predictable ride.
To Creaking suspension
