Service ABS/Traction Control
Old Oct 17, 2007 | 08:00 PM
dmoore's Avatar
dmoore
Default Service ABS/Traction Control
Every couple of weeks I start my car and the DIC and lights come on and tell me to service the ABS and Traction Control. Turn the car off wait a couple of minutes and the lights and reading on the DIC goes away.
What the heck is going on? Any advice?
Old Oct 17, 2007 | 08:26 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Check your codes on the DIC and see what you get .... I think your going to meet the ABSfixer soon though
Old Oct 17, 2007 | 09:24 PM
Ta-taaa's Avatar
Ta-taaa
Did you try posting over in the Tec section?
Good Luck!!
Old Oct 17, 2007 | 10:37 PM
LGCC Mama's Avatar
LGCC Mama
4th Gear
I am having the same problem, but the service ABS comes on after hitting a bump. If you turn off the ignition and restart the car, it goes away. Anybody come up with a solution?
Old Oct 17, 2007 | 10:48 PM
C908's Avatar
C908
Default I get the same reading
[ QUOTE=LGCC Mama;1562356135]I am having the same problem, but the service ABS comes on after hitting a bump. If you turn off the ignition and restart the car, it goes away. Anybody come up with a solution?[/QUOTE] I have a hump I have to back up on when coming out of the garage. I have to crank the wheel all the way to the left and that is when I see the service ABS. After turning off the car and restarting the reading goes away.
Old Oct 18, 2007 | 07:19 AM
bassvet's Avatar
bassvet
St. Jude Donor '10
Same problem a while back: bad steering column sensor had to have it replaced.........
Old Oct 18, 2007 | 08:00 AM
Zoom Lolly Vette's Avatar
Zoom Lolly Vette
Had the same thing happening on my 2001 Vert and fixed just by cleaning and retighting the 2 groud leads which are located behind the headlamps inside the engine bay .
Did it about a couple of months ago and problem never came back .
Everything just fine now .
Old Oct 18, 2007 | 08:05 AM
Zoom Lolly Vette
I had the very same problem with my 2001 Vert and fixed it just by cleaning and retightening the 2 ground leads located inside the engine bay, behind the headlamps .
I did it a couple of months ago and problem never came back so far .
There is a very detailed and interesting thread about this by Bill Curley on this forum that will give you all information needed to fix it by yourself .
Old Oct 18, 2007 | 08:09 AM
Zoom Lolly Vette
I had the very same problem with my 2001 Vert and fixed it by cleaning and retightening the 2 ground leads that are located inside the engine bay, behind the headlamps . I did it about a couple of months ago and problem never came back so far . You should look at a very interesting and detailed thread about this common problem by BIll Curley on this Forum .
To Service ABS/Traction Control
