Cam?
Old Oct 19, 2007 | 01:44 AM
blkshrk81's Avatar
blkshrk81
Default Cam?
So, I'm thinking about getting a cam, but no very little about them. What do all the numbers mean when looking at a cam's specs...such as - 224/228 - .534/.537 w 1.7 rocker - 112 LSA? Thanks for the help!
Old Oct 19, 2007 | 02:08 AM
deathinnovember's Avatar
deathinnovember
I'm a n00b my self. But I'll try to help out. The first two numbers are the grind. Pretty much means how agressive the cam is. The Z06's cam is in the lower 200's and once you get past the 225 range it starts getting pretty agressisve. The LSA is the lobe speration angle. I'm not exactly sure what that determines but generaly they go from 111-115 on LSX cams and the higher the LSA the less cam loop you'll have.
If I'm wrong on any of this someone correct me!
Old Oct 19, 2007 | 04:20 AM
rtsb's Avatar
rtsb
Try this link it should help
http://www.ls1tech.com/forums/showthread.php?t=327734
Old Oct 19, 2007 | 08:20 AM
stormrider's Avatar
stormrider
Originally Posted by rtsb
Great link, thanks for sharing!!
Old Oct 19, 2007 | 12:59 PM
blkshrk81's Avatar
blkshrk81
Thanks for the link. It helped a lot! So, what's a new cam gonna end up costing me after I replace everything else...valve springs, etc?
Old Oct 19, 2007 | 05:23 PM
rtsb's Avatar
rtsb
Old Oct 19, 2007 | 06:14 PM
Corvette Don's Avatar
Corvette Don
224/228 is the intake and exhaust duration in degrees and the .534/.537 is the Intake and exhaust valve lift, 112 is the lobe seperation angle, a 112 would have a chopy idle and a 114 lsa would ahve a smoother idle.
Old Oct 19, 2007 | 06:15 PM
Corvette Don
I had a quote last weekend and this was what they sent me this is with out a new clutch and with out a good cold air intake.
Install camshaft 1,200.00
Dyno tune 450.00
American Racing headers installed 1,995.00 -
1 Custom grind camshaft XER-273HR 375.00
1 Timing cover gasket 12574294 28.72 -
1 Front crank seal 12585673 16.84
2 Water pump gaskets 12588372 10.20
1 Crank balancer bolt 12557840 5.64
1 LS2 timing chain 12586482 46.81
1 Push rod set 7.450 long 7955-16 145.00
8 NGK TR6 Spark plugs 3689 24.00
2 R134 Refrigerant 6012-JENSEN 15.00
6 Synthetic engine oil 5-30M1 45.00
2 Gallon Extended life coolant 999999 30.00
1 Quart PStrg fluid M27-32 4.38
1 Inake manifold seal kit 12533587 47.02
1 Valve Spring set 26918-16 230.00
Sub Total 4,668.61
Tax 382.83
Total $5051.44
You can get most of that yourself and take it to them and save even more money, some of those prices are a bit high.
Old Oct 19, 2007 | 06:22 PM
AFRob's Avatar
AFRob
I don't want to thread hijack.
RTSB--could you PM me with where you're planning on having the work done? I'm thinking about roughly the same mods.
Rob in Eatonville
Old Oct 20, 2007 | 07:56 AM
rtsb's Avatar
rtsb
Not really I checked on a couple of websites and some of the parts are cheaper but the cam thru comp is more than what he quoted and some other stuff I checked also.It all evens out.
To Cam?
