Hyper left blinker! How to replace bulb?
Old Oct 19, 2007 | 03:55 PM
WantstobuyaVette's Avatar
WantstobuyaVette
Default Hyper left blinker! How to replace bulb?
My left blinker started blinking like crazy when ever its on now. And I also noticed that my amber light in the front left of my car is also out. How hard is it to change out this bulb and where can I buy a replacement bulb at?
Old Oct 19, 2007 | 03:58 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
The bulb can be bought at any auto parts store. To replace you have a couple options.
1. Go in through the front brake duct. Push the duct back, up, and out of the way.
2. Turn the headlights halfway up and reach in through the opening. Have to have really small hands and arms for this one.
3. Raise the front of the car and go in through the access panel under the front lip.
Number 1 is the fastest and easiest, if your arms aren't too large.
Any of the three are easy to do, just get in there and get busy.
Old Oct 19, 2007 | 04:03 PM
EtidW's Avatar
EtidW
Any auto parts store. Just reach through the opening for air to the breaks and move the ducting out of the way then you will be able to reach up and get to the socket for the bulb there is a tab that needs to be pressed then turn the socket and pull out through the hole the remove the bulb and replace with a good one and put every thing back. The whole process takes 2 minutes tops, CAUTION you need to have a smaller hand or get someone who does. You can jack the car up and remove the panel forward of the front wheel but that takes more time.
Old Oct 19, 2007 | 04:11 PM
WantstobuyaVette
So I can just go to autozone and ask for the front amber replacement bulb and that will also fix the hyper left turn blinking??
Old Oct 19, 2007 | 04:46 PM
93v's Avatar
93v
Yes it will,just did it last week
Old Oct 19, 2007 | 05:09 PM
WantstobuyaVette
you got your hand in there or did you have to jack up the car?
Old Oct 19, 2007 | 05:32 PM
EtidW's Avatar
EtidW
I did two cars got my hand in but my friend could not.
Old Oct 22, 2007 | 08:26 PM
93v's Avatar
93v
couldn't get my hand in there,had to take the cover off the headlight 4 screws i think, then reached down in aside the headlight unplug the bulb then get it out through the brake duct hose.Do a search for this there are other posts on this. good luck
Old Oct 22, 2007 | 09:07 PM
RonJ's Avatar
RonJ
This worked for me when I had to change the bulb on vacation.
Cost me a bit of blood 'cause my hands and arms aren't that small ..
RonJ ...
To Hyper left blinker! How to replace bulb?
