Reverse Light Bulb Replacement
Old Oct 20, 2007 | 11:01 AM
STRATTON's Avatar
STRATTON
Default Reverse Light Bulb Replacement
Before I break something accidently, can someone tell me how to get to the reverse bulb on a 2000 Coupe?
Old Oct 20, 2007 | 12:52 PM
65GGvert's Avatar
65GGvert
Take out an inside (closest to the license plate, not inside the car) tail light ***'y and reach in through the hole to get to the bulbs. Reach in, depress the little clip and rotate ccw and the socket and bulb will come out. Push in and rotate ccw on the bulb. Install new bulb, replace socket into backup lamp housing, then reinstall tail lamp
Old Oct 20, 2007 | 01:44 PM
Pres712's Avatar
Pres712
Default Or
That's one way to do it or you can take off the license plate bracket asembly. Remove your license plate and there are 4 torq screws; take them out and the entire assembly comes out. There are the two blub sockets; as he said just turn them and viola!!!
Old Oct 20, 2007 | 04:33 PM
STRATTON's Avatar
STRATTON
Default Reverse Light Fix
Thanks guys, I'm on it!
To Reverse Light Bulb Replacement
