Leaking seal?
Old Oct 21, 2007 | 11:25 AM
steve8's Avatar
steve8
Default Leaking seal?
My 04 has just started leaking at the all too common left seal on the rear end.
What is the most important part of this fix to ensure it is done correctly, the proper sealant?
Obviously the seal/O ring is replaced, but I would prefer to just have this done once.
Old Oct 21, 2007 | 08:19 PM
steve8's Avatar
steve8
No advice for the dealer?
Old Oct 21, 2007 | 08:24 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Im guessing someone will chime in partner...be patient!
Old Oct 21, 2007 | 08:35 PM
Just find a shop or dealer that has a good reputation for working on these cars. Check and see if they have replaced the seal before and see if you can speak with the car owner to see how it has held up.
Old Oct 21, 2007 | 10:36 PM
rrichar2591's Avatar
rrichar2591
Also If your out of warranty, I would make sure that they guarantee their work. Mine had to go back 4 times over a 3 year period before they got it.
Old Oct 21, 2007 | 10:39 PM
moserbe's Avatar
moserbe
That's not too promising.
Old Oct 22, 2007 | 12:15 AM
C5naples's Avatar
C5naples
Make sure you go to someone who is very used to working on Vettes and knows about this problem and how common it is. If you had a reputable dealer nearby, they at least has fixed this many, many times.
I had to take mine back a second time because the housing had some very small hairline cracks in it causing it to still leak a little. Good luck!
Old Oct 22, 2007 | 06:48 AM
steve8's Avatar
steve8
No problem as I'm still under original warranty, and I just purchased a 4 yr zero deductible gmpp. I just want it done once.
To Leaking seal?
