Wheel Question...Will they fit?
Old Oct 22, 2007 | 05:08 PM
NavyC5's Avatar
NavyC5
CI 3-4-5-6-10 Veteran
St. Jude Donor '03-'06-'08-'09-'10
Default Wheel Question...Will they fit?
A friend of mine is looking to buy a set of wheels for his 1998 Corvette, non Z51, stock suspension. Another friend has a set of 18x9.5's that he wants to sell. The wheels are a +43et offset with a 5x120 bolt pattern. Will these wheels fit without having any clearance issues?
Old Oct 22, 2007 | 08:43 PM
NavyC5's Avatar
NavyC5
ttt
Old Oct 23, 2007 | 06:08 PM
NavyC5's Avatar
NavyC5
ttt
Old Oct 24, 2007 | 07:34 AM
cenzo's Avatar
cenzo
Ryan, each wheel will sit about one inch further outboard than stock C5wheels. If your friend can live with that, he'll be okay.
https://www.rsracing.com/tech-wheel.html#patterns
Old Oct 24, 2007 | 09:56 PM
NavyC5's Avatar
NavyC5
Excellent. Now how do I measure the wheel to make sure it is the offset the owner is claiming.
Old Oct 24, 2007 | 10:07 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If all 4 are the same...
The rears will fit flush with the fenders, about the same as stock Z06 wheels fit the body.
On the front, they will hang out of the fenders about 3/8".
To measure if stated offset is correct, lay a straightedge across the rim lip on the backside of the wheel, and measure down to the mounting hub. (this is the actual backspace dimansion)
You should measure about 7" backspace, for a 43mm offset 9.5" wide wheel (which will measure 10.5" overall width).
Old Oct 24, 2007 | 10:10 PM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
Is he interested in a set of Chrome Wagon Wheels in nice condition, with near new BFG T/A KDW tires and sensors?
Bruce
Old Oct 25, 2007 | 05:36 PM
NavyC5's Avatar
NavyC5
So, just out of curiosity, if he already has the wheels and they hit the calipers then something is wrong with either the design of the wheel or they are not a +43 offset?
Old Oct 25, 2007 | 06:38 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Could be the design of the wheels, and/or the lack of contour in the spokes. If the wheels have a very fat lip, that eats up caliper clearance, but the wheels could still be at that offset.
If they hit the calipers at a 43mm offset, just think how bad they'd hit if the wheels were a (more proper for a C5) 54mm offset (it would be even worse).
Old Oct 26, 2007 | 05:08 PM
NavyC5's Avatar
NavyC5
The wheels are a Ruff Racing 278. Anyone have experience with this wheel?
Old Oct 29, 2007 | 06:15 PM
JOEY P's Avatar
JOEY P
I have ruff 279s and when I got them they hit the rear caliper....I had to put a 5mm spacer so the would clear the rear caliper.
Old Oct 30, 2007 | 08:14 PM
NavyC5's Avatar
NavyC5
Yeah, that's what I'm running into. To say I'm not happy is an understatement
To Wheel Question...Will they fit?
