Please help "Engine light?"
Old Oct 22, 2007 | 07:15 PM
Tombone's Avatar
Tombone
Default Please help "Engine light?"
1999 38000 miles.
I had a discharged battery issue............recharged it all seems fine?
Dash engine light is on..............any ideas.
Thanks,Tom.
Old Oct 22, 2007 | 07:16 PM
Divine_Spear's Avatar
Divine_Spear
What does your owner's manual say about it?
Old Oct 22, 2007 | 07:21 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Pull the codes from the DIC and post them....probably minor and you can reset the codes and walla light is gone!
http://www.stengel.net/diccodes.htm
John
Old Oct 22, 2007 | 07:35 PM
chazzvette's Avatar
chazzvette
Default check engine light
Pulled codes after I got a check engine light. Code PO410, which I searched is a air sensor code. I reset, but it comes back after about 5 starts. Do I need to replace the sensors, or is a program needed to clear this. No mods. Local corvette shop says $75 to clear code. Thanks
Old Oct 22, 2007 | 07:37 PM
chazzvette's Avatar
chazzvette
Sorry....I didnt mean to jack this thread....my fingers are to quick, and I get excited when I talk "corvette"
Old Oct 22, 2007 | 07:39 PM
0JPM@AutoBuffs
Former Vendor
Had the same code...went away on its own...havent seen the little bugger since
Tombone's Avatar
Tombone
I just checked the codes it came up with this.
10-PCM - Powertrain Control Module
Old Oct 22, 2007 | 07:41 PM
Vega$Vette's Avatar
Vega$Vette
It should has a 4 digit # and a H or C after it?
Jet-Jock's Avatar
Jet-Jock
1999 38000 miles.
Thanks,Tom.
This is normal, clear your codes and it will be back to normal.
1) Turn on the ignition but don't start the engine.
2) Press the "RESET" button to turn off any warning messages
3) Press and hold "OPTIONS"
4) While holding "OPTIONS", press "FUEL" four times within a 10-second period.
Initially, on-board diagnostics go into an "Automatic Mode" which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. If none are present in a given module, you will see "No More Codes" on the display.
To reset the codes once in manual mode, press and hold "RESET" until it displays "NO CODES". Press "OPTIONS" to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
Old Oct 22, 2007 | 08:02 PM
Tombone's Avatar
Tombone
Your method did cancel the light.
But am I ignoring a problem?
Old Oct 22, 2007 | 09:27 PM
Jet-Jock's Avatar
Jet-Jock
Eeek I responded to your PM same comment.
For the others this was my response:
No, the problem was you had low voltage on the PCM. That made the computers upset and thus they set codes. Whether you knew it or not, your system was placed into a disabled mode and if you have been driving it you probably were getting horrible gas mileage. That is by design.
Clearing the codes just reset the condition as long as you now have good voltage you should not have any of those codes re-occur. Matter of fact even while it is running, you can activate and view the codes to see if any occurs. You shouldn't see any unless you have other unrelated problems.
Also, if you have not dealt with the service column lock issue by adding a bypass module or having rev C of the recall done, you can expect the service column lock to show its ugly head on you. It is generally caused by low voltage on the powertrain control module.
Old Oct 22, 2007 | 09:52 PM
Tombone's Avatar
Tombone
Did the column lock by adding a bypass module not sure what you mean by the rev C recall?
Thanks, Tom.
Old Oct 23, 2007 | 07:17 AM
Jet-Jock's Avatar
Jet-Jock
Thanks, Tom.
This is the recall notice:
Recall Bulletin
Rev C means they first do the K harness, then the reprogram and finally remove the steering wheel and replace the column lock plate with a modified plate which is missing the holes for the pins to go into. Supposedly fixing the problem.
I did the bypass module too.
Old Oct 23, 2007 | 07:21 AM
Tombone's Avatar
Tombone
Thanks for all your help!
Recall Bulletin
To Please help "Engine light?"
