[Z06] I Need Help.... ?? Blew a Piston Ring
Old Oct 22, 2007 | 10:48 PM
BonestockZ06's Avatar
BonestockZ06
Default I Need Help.... ?? Blew a Piston Ring
Yesterday my engine light came on while cruising on the highway. I took it to my friends shop and put the scanner to it. It gave me the po300 and po654 and it showed a severe misfire on #7. I I replaced the spark plugs, wires, and coil packs and nothing, still lit the ses and showed a misfire on #7. I checked my oil and was 1qt low.
Next a compression test on all the cylinders, average was 135 till I got to #7, it showed zip zero. The original plug out of that cylinder had oil on it as well. I took it apart today, I just got to removing the head and everything looked good. I did the water test on the valves and passed with flying colors. I went on to the water test on the cylinders and guess what, #7 swallowed it immediately.
This is what I need to know:
  1. Part number on the rings for a 2003 zo6
  2. Where can I get them asap besides the dealer
  3. can I use the same metal head gasket
  4. are they stock replacement or is there file fitting involved?
Any help you guys can give me will be greatly appreciated. I'm very mechanically inclined, but this will be my first experience with a vette.
Old Oct 22, 2007 | 11:05 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Has your car been tuned? Many so-called tuners tune these cars too lean and you break the rear pistons because they get the most direct shot of air from the intake manifold.
I'd have said it was a valve spring breakage (far more common issue), but sounds like you've covered that.
Old Oct 22, 2007 | 11:11 PM
BonestockZ06
Yeah, the heads and valvetrain looks great. I'm not the original owner, but I can tell you that for as long as I owned it, it has not been tuned or touched by anyone.
Old Oct 25, 2007 | 01:13 AM
aweil's Avatar
aweil
You'll need a new piston as well.
Old Oct 25, 2007 | 01:27 AM
crazyv6's Avatar
crazyv6
Is there an October special for a LS6 from a vendor? Or, you could call up Katech and get their 427 short block!
Old Oct 25, 2007 | 01:29 AM
crazyv6's Avatar
crazyv6
Found it...
http://forums.corvetteforum.com/show....php?t=1831154
Old Oct 25, 2007 | 03:37 AM
Wicked_Z06's Avatar
Wicked_Z06
Being an engine builder...
I absolutely hate the idea of replacing the piston in the car. Seems like more R&R shops have been doing this lately. The new rings wont break in properly if you don't have a nice cross hatch/hone job on that cylinder bore. Unfortunately for people on a budget, they will not pay the price to have it done correctly. If this were my vehicle, I would tear down the entire engine, and rebuild it. Assure all new machine work is applied before I spend money on fixing the problem.
As for the head gasket, I would suggest replacing it.
Old Oct 25, 2007 | 09:25 AM
Millenium Z06's Avatar
Millenium Z06
Moderator
Old Oct 25, 2007 | 10:35 AM
Diceman9's Avatar
Diceman9
Make sure its the piston/and or ring. Check all the valve springs....mine did the same thing....no compression. After dealer looked at it.... broken valve spring pretty easy fix.
Old Oct 25, 2007 | 10:39 AM
BonestockZ06
Done deal, I'm going for a new motor.. Found out the piston blew the oil ring and landing and bent the rod as well. The search is on for the best place to purchase.
Old Oct 25, 2007 | 12:19 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
If you want a crate type deal. Take a look at Scoggin Dickey. They have great prices for GM Performance crate motors. Last I checked a complete LS6 was under 6K.
Old Oct 25, 2007 | 12:44 PM
Zee916's Avatar
Zee916
Good call replacing the motor. Certainly the right thing to do.
Old Oct 25, 2007 | 12:50 PM
crazyv6's Avatar
crazyv6
Originally Posted by dwjz06
If you want a crate type deal. Take a look at Scroggin Dickey. They have great prices for GM Performance crate motors. Last I checked a complete LS6 was under 6K.
Or, Gene is selling them for $4795 right now. Just check my previous post.
Old Oct 25, 2007 | 12:56 PM
dwjz06's Avatar
dwjz06
Dogface
Sorry. Did not click the link. Good Price from Gene.
Old Oct 25, 2007 | 01:07 PM
crazyv6's Avatar
crazyv6
Kewl, I was just trying to save bonestock some $.
Old Oct 25, 2007 | 01:18 PM
dwjz06's Avatar
dwjz06
Dogface
Yeah me too. There was a catolog I saw a while back that had some crazy prices on engine packages. Don
Old Oct 25, 2007 | 01:43 PM
BonestockZ06
Will do. Thanks
Yeah, my conscious will kill me if I don't do it right. It just wouldn't feel right.
Definitely will consider Gene, just trying to decide if now that I'm going to replace the engine, Do I stay stock, I should I go for one with better rods/pistons and perhaps more HP...
I truly appreciate the gesture.
Ok, so another update.. I decided to pull #8 (bent rod), #5 (bent rod) and #6 (looked fine). I stopped there, I couldn't stand to watch anymore. I think this was caused by a hard downshift a couple of weeks ago and it just finally caught up with me. It's the only thing I can think off .
Thanks again guys, the search continues..
I will post pics for you guys later on tonight.
To I Need Help.... ?? Blew a Piston Ring
Old Oct 25, 2007 | 01:59 PM
dwjz06's Avatar
dwjz06
Dogface
Yep no rev limiter to help on a mechanical over rev. Good luck on your search.
Old Oct 25, 2007 | 03:42 PM
Millenium Z06
Moderator
I like the Scoggin Dickey crates myself.
Old Oct 25, 2007 | 03:55 PM
Z06Electron's Avatar
Z06Electron
You could save yourself some money and go with a 383 stroker rotating assembly since it sounds like your block is ok. Have the machine shop do the honing and rebuild it yourself, they go on ebay for $1300-2000 for a forged 383 rotating assembly, and Tbyrne sells them for less than $2700. Even $3000 with machine work is less than a new crate block, and everything will be forged with more cubic inches of displacement.
