DIC message
Old Oct 23, 2007 | 11:46 AM
bucwheat's Avatar
bucwheat
Default DIC message
Hello vette heads,I have a problem I'm sure someone has an answer for ,A few weeks ago my DIC read "trans temp high" and when I tried to bring up the temperature the DIC read trans temp XXX. well I've driven it twice sence then with no problem then on Sat. I went about a mile and the DIC read high trans. temp,I shut the motor off and started it back up with no message showing. I'm thinking Temp. sensor because the temp. had no time to warm up at all. Any input would be helpful.My baby is a 1998 C-5 auto with 49,000 miles .
Old Oct 25, 2007 | 08:44 AM
bucwheat's Avatar
bucwheat
Does anyone have a comment? Or does this forum get read?
Old Oct 25, 2007 | 08:48 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
That kind of comment probably made a few people decide NOT to answer.
ANYWAY, I could only guess on this that the trans temp sensor is acting up or no good at all any longer. Just a guess.....
Old Oct 25, 2007 | 09:15 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Could be a bad connection (dirty etc.) or it could be a sensor.
Chase your wiring back there and pop your quick disconnects and clean them (electrical cleaner).
When I say chase your wires I mean check for any wear of the insulation or see if they are broken.
Check and tighten all your grounds there is an electrical sticky on this. I think the sensor itself is at the tranny, but I am not to sure.
I think if you could buy a complete C5 harness and rewire the puppy every 4 or 5 years the C5 would have no problems at all.
Oh, and like Glenn said. Be patient waiting on an answer. Someone will get back to you.
There is enough knowledge on this forum to build a C5 from scratch.
Regards,
The Pup
Old Oct 25, 2007 | 09:21 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Regards,
The Pup
These are the actions to take first.
If the problem persists after verification of the above, get back to us.
Old Oct 25, 2007 | 10:54 AM
jrose7004's Avatar
jrose7004
Bucwheat you might want to fill out your profile and learn to be patient.
Old Oct 25, 2007 | 01:46 PM
bucwheat's Avatar
bucwheat
Sorry for the miss understanding,I'm new to the forum and don't quite understand how everything works...I was just wondering if this was an old forum that no one visits anymore.
Old Oct 25, 2007 | 01:51 PM
bucwheat's Avatar
bucwheat
Regards,
The Pup
You are most likly on the money,My son-in-law and I replaced the A/C compressor about 2 months ago and had to remove the waterpump as well which is in the general area, I'll look at the connection tonight. Thanks Pup, Bobby(BUCWHEAT)
Old Oct 25, 2007 | 01:52 PM
bucwheat's Avatar
bucwheat
OK,how do I do that?........fill out a profile.
Old Oct 25, 2007 | 01:56 PM
hotwheels57's Avatar
hotwheels57
On the main menu page, where all of the forums are listed, scroll down to the bottom of the page to the Help Forum. It's a forum for all non car related site questions.
You can use that forum to ask questions on "How do I...?" (post an image, add an avatar, quote another post, copy a link, etc)
Basically, you click on your user name (or user cp in the red banner above) and follow the prompts.
If you look around that forum, it's probably already been asked and answered by other new members.
http://forums.corvetteforum.com/forumdisplay.php?f=31
FYI, it's the forum where you apparently originally posted this question and it got moved.
Old Oct 25, 2007 | 02:00 PM
Bill Vett's Avatar
Bill Vett
Go to "user cp" under reply to thread at the top left of this page. Click on it and go to profile. The reason you should have where you live is , someone from your immediate area may be able to give you a hand. Good luck ..... Bill
Old Oct 25, 2007 | 02:03 PM
bucwheat's Avatar
bucwheat
Thanks muchly!
Old Oct 25, 2007 | 02:04 PM
bucwheat's Avatar
bucwheat
Thanks Bill,I'll look at it rat now.
To DIC message
