[Z06] titanium exhaust flanges?
Old Oct 23, 2007 | 10:32 PM
AlwaysInBoost's Avatar
AlwaysInBoost
Default titanium exhaust flanges?
does anyone know where I can purchase a couple titanium v-bands or even two bolt flanges? I want to make some modifications to my exhaust but can't find these parts anywhere...
TIA.
Old Oct 23, 2007 | 11:30 PM
BlackZ06's Avatar
BlackZ06
I'd call and talk to a local welding shop. They may either have the parts, or have an idea where to get them.
Note a couple of things .....
* Welding titanium is a more complex task that "regular" welding. The weld area has to be protected by inert gas ... for more info take a look here ...
http://www.timet.com/fab-p27.htm
* Titanium is HARD. If you plan on trying to cut it or drill it, think about taking it to a machine shop. It is not an easy material to work with.
BTW, Timet is the supplier for the flanges used on the Z06 ... from an article in "Automotive Industries" back in 2000 ...
"Now, exhaust system supplier ArvinMeritor, and Titanium Metals Corporation (TIMET), the world's largest Ti manufacturer, believe the time is right for a significant push into the auto industry. The two companies co-developed the 26-pound Z06 exhaust system, which is 44 percent lighter than the Corvette's standard 46-pound stainless steel system."
Old Oct 23, 2007 | 11:36 PM
socal guy's Avatar
socal guy
any reason you dont want to use a standard SS clamp?
Old Oct 24, 2007 | 03:21 AM
Davinss's Avatar
Davinss
Can you cut titanium with a plasma cutter?
Old Oct 24, 2007 | 04:42 AM
BlackZ06's Avatar
BlackZ06
You can, but the high heat and gases in the plasma causes contamination of the titanium. If the cut edge is to be welded later, the contaminated area has to be removed by grinding.
Apparently high pressure water (with abrasives in the water) cutting is now the most "accepted" method for cutting titanium, especially if welding is to follow the cutting process.
Old Oct 24, 2007 | 07:03 AM
PA Z06's Avatar
PA Z06
Call me, are we talking about a bypass mod
Old Oct 24, 2007 | 08:11 AM
AlwaysInBoost
you can't weld SS and titanium together.
Thanks for the info BlackZ06.
AlwaysInBoost
not so much
To titanium exhaust flanges?
