Fuel Filter on a 99???
Old Oct 25, 2007 | 08:57 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Fuel Filter on a 99???
Neighbor has a 99 and when he comes up to a light on occasion the car bucks and stalls like it’s starving for gas. It’s an A4.
Restarts great and with no problem and runs like a BOH under throttle or WOT.
It’s never had the Fuel Filter changed.
He thinks it’s something in the tranny a solenoid or something, and I told him to change out the fuel filter.
Any ideas??????
The Pup
Old Oct 25, 2007 | 10:58 AM
02MillenniumVette's Avatar
02MillenniumVette
If its never been changed then I would start with that first. Hopefully he hasnt clogged his injectors yet.
Old Oct 25, 2007 | 11:22 AM
Oldvetter's Avatar
Oldvetter
Change the fuel filter AND add a bottle of Techron to the tank.
Old Oct 25, 2007 | 11:51 AM
mcgilles's Avatar
mcgilles
its a cheap and easy fix. if its not the source of the problem, it certainly won't hurt to get it done. how many miles on the car now?
my SHO had a similar problem a while back. it would stall frequently when the engine speeds would go down such as when at stoplights. it would be worse in parking lots while turning, the power steering pump load would cause the engine to stall. I replaced the fuel filter, and on a couple of occasions ran fuel system cleaner through it. it took about 3 bottles with a few tanks of fuel to finally clean it up, but the car has been running great ever since.
Old Oct 25, 2007 | 01:23 PM
bighank's Avatar
bighank
Default Then plugs wires clean MAF and TB
Old Oct 25, 2007 | 01:36 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the PCV to instake connection. The rubber hose there can and will develop a hole on it. It happened to my '99.
Old Oct 25, 2007 | 03:49 PM
Benpup's Avatar
Benpup
It's got about 110K on it and it's never been changed. That's why I believe it's the filter.
Regards.
The Pup
Old Oct 25, 2007 | 03:56 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
If it runs like a BOH under WOT it is not a plugged fuel filter. This sounds more like dirty injectors, bad plugs or wires, or an air leak. I have 113,000 miles and have not changed the fuel filter, no problems.
Old Oct 25, 2007 | 04:46 PM
WKMCD's Avatar
WKMCD
I think the first thing I would do is clean the MAF - CAREFULLY. Then a double dose of Techron to clean the injectors.
My $.02
Old Oct 25, 2007 | 05:03 PM
R Devil's Avatar
R Devil
Old Oct 25, 2007 | 08:17 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I recently had the exact same problem........It was an air leak, check the air bridge area. Hopefully thats all it is.
Old Oct 26, 2007 | 04:13 PM
bighank's Avatar
bighank
Default Watch it mine leaked live a sieve when a plastic connector failed
Had about 70K on my 98 and one day I saw a huge amount of gasoline at the left rear fender dripping under the car. I was one of the plastic snap connectors going in to the filter. When replacing the filter make sure you change BOTH connectors including the one on the fuel line. If not you are asing for trouble. BIGHANK
To Fuel Filter on a 99???
