Winter Storage
Old Oct 25, 2007 | 05:04 PM
bill bradford's Avatar
bill bradford
Default Winter Storage
I am getting ready to put her away for the winter. Would appreciate any thoughts how to best maintain the car. I am wondering if it is necessary to fill the tank with gas, and change the oil. I have a trickle charger to maintain the battery. Thanks, Bll
Old Oct 25, 2007 | 06:37 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I put mine away yesterday. I changed the oil, filled it with gas, added Stabil, and over inflated the tires. I've never used a battery charger. I just disconnect the negative battery terminal. I've done that for 7 years and it starts right up in the spring. I also parked it on a large piece of plastic to keep moisture from coming up through the concrete floor. I put several bars of Irish Spring soap inside the car and in the engine compartment to deter those pesky little mice. I also put 2 large boxes of baking soda inside the car to help with moisture. Last but not least, make sure your car is clean before you cover it.
Old Oct 25, 2007 | 06:40 PM
Zozzie's Avatar
Zozzie
If you do a Search here, on other Vette sites and Google you will find much information on storage. It's a popular question.
Old Oct 25, 2007 | 07:14 PM
deathinnovember's Avatar
deathinnovember
I never thought of the baking soda or soap before. I'm sure that really helps with the musty smell too. I'll have to do that this year.
Personly I've always filled up the tank , washed it , and parked it in a storage unit. I drove there to start it up once a month and let it idle for about 30 minutes . I didn't even cover it. It turned out just fine in the spring. I've done this along as I've owned a nice RWD car.
But no matter what you do. Make sure you check the PSI in the tires in the spring and make sure to drive the car real carefuly for a half hour just to make sure nothing has locked up during the sit.
Old Oct 25, 2007 | 07:49 PM
HG's Avatar
HG
Here is a very comprehensive article I found.
http://www.corvetteactioncenter.com/...e/storage.html
Old Oct 25, 2007 | 09:15 PM
bill bradford
Old Oct 25, 2007 | 09:20 PM
Here's what I do. Get the gas tank almost empty and then when you fill up, put in a bottle of Sta-Bil to keep the gas fresh during storage. Change the oil, detail the car, and hook the battery to a battery tender. You can also put carpet squares under each wheel to keep them off the cement and I put in a few extra pounds of air in each tire.
If you are worried about pests, then put a plate of mothballs under the hood and in the interior. You may also want to put in some moisture absorbing packets in the interior if you are worried about it.
Old Oct 29, 2007 | 01:30 PM
MN81C3's Avatar
MN81C3
I use Bounce Dryer Sheets - put them all over the engine, in the glove box, on the floors and even in the tail pipes. The car smells great in the spring and no unwanted guests.
To Winter Storage
