Oil Pressure Gauge
Old Oct 25, 2007 | 10:33 PM
MorpheusGPR's Avatar
MorpheusGPR
Default Oil Pressure Gauge
My gauge is slow to respond when the car is started...at first it sits then slowly works its way up. Is this normal or do I have an issue? Once at speed, say 75ish mph the digital gauge is showing pressure around 40-41psi
Old Oct 26, 2007 | 09:02 AM
MorpheusGPR
nonone?
Old Oct 26, 2007 | 09:06 AM
RICorvetteGuy's Avatar
RICorvetteGuy
From: The smallest and most corrupt state in the nation. Rhode Island
The pressure sounds fine but as for the slow reaction at startup.. ummm
Are you using Mobil 5-30 or something heavier ???
What is the temp outside when this happens ?
What is the pressure at idle ?
Old Oct 26, 2007 | 09:12 AM
MorpheusGPR
I just picked it up but if I recall the pressure was around 20-25 at idle, the temp was in the mid 50s or so and its got mobil1 in it, I assume 5w-30.
Old Oct 26, 2007 | 09:31 AM
RICorvetteGuy
Ummm, you know what happens when people assume, right...
First thing I would do is change the oil and filter and make sure you have only Mobil 5-30 Synthetic in it and then go from there.
How long have you had this car and this situation ???
Has it always done this or did this just start to happen ?
20-25 at idle is not bad... 30 would be better though. but the slow to respond, ummm
When you say slow to respond ... about how long do you mean and do you hear any valve train noise while the pressure is building ??
Old Oct 26, 2007 | 09:38 AM
z06Bigbird's Avatar
z06Bigbird
Could change out sending unit if not too expensive. DIY, I hope.
Old Oct 26, 2007 | 09:46 AM
RICorvetteGuy
Ugh..... Sending units going bad is very very common but changing them out is not a fun task if you have not done it before...
Requires removing the intake and some hoses to get to it. Others on here have even resorted to cutting holes in the front cowl area and then resealing them so they did not have to remove the intake.
Plus, when they go bad they normaly read very high pressure 80 plus on the gauge and 120+ on the dic.
I don't think that is the situation here..
Old Oct 26, 2007 | 10:36 AM
MorpheusGPR
The previous owner used mobil synthetic 5w30 I am sure. Its due for an oil change in about 500 miles...I just drove it home yesterday
If I need a new sender, its going to be done right, and there will be no unecassary cutting of anything. That just does not make sense to me.
Its not like it takes a min or anything, its right after start it will hesitate for a spit second, then slowly work its way up the gauge to where it settles out to a pressure. I have to take my boat in to be winterized, when I get back I will double check the idle pressure.
Old Oct 26, 2007 | 12:52 PM
RICorvetteGuy
if it is only a few seconds then that is very normal.
I just went out and looked at mine and it was about 2-3 seconds before it went to full pressure at idle. mine is at 40 psi at idle ( cold )
I thought you meant it was taking a long time as in mins.
I would just get the oil and filter change done and you should be fine.
Old Oct 26, 2007 | 11:42 PM
MorpheusGPR
Ok, no this is a matter of seconds. My truck jumps right up so I was not sure if this was normal on the corvettes or not. Sounds like it is, does yours do a slow gradual climb to pressure and not an abrupt jump? Just going to take some getting use to after watching my truck gauges for the last 75k+ miles.
I was out of town today so I just got home and have not been able to check the pressure at idle, but will do so tomorrow, cold and compare to your 40psi using the digital gauge.
Sounds like this is typical then.
To Oil Pressure Gauge
