[Z06] Build or Blow?
Thank you all for your help,
Michael.
If I had a budget limit of $6k and wanted a nice hotrod Z06, I would do good headers (AR/LG/Kooks), do the drill mod on the stock airbox, do a quality cam package, with an underdrive pulley, and do the clutch, with an aluminum flywheel. That's $6k right there.
I would not crack the engine (take off or change the heads) at a $6k limit, especially since a Z06 already has pretty good heads. I would not even consider FI without an available budget at least double that.
A car built like I outlined above would make 425 or so at the rear wheels, a bit more if you went really wild on the cam. It would be reliable and fun to drive, would run high 11s at the strip with decent driving, and would top out somewhere over 180. Very sensible and fun combo.
Don't try to do too much hotrodding on too little money. That way lies misery.
Just ime. Good luck in your pursuit of your dream car!
Like has been said, you will need a clutch and fuel if you do either of these which will be upwards of $2000 w/ install if you are not wrenching yourself.
On a stock motor, 8lbs max for a blower unless you got the ***** to push 10, which I would not recommend. Most people leave it around 5-6 and you can still make 500+ pretty easily with a conservative tune.
Now heads/cam can be done for 6K. You won't have the top line parts (heads mostly), but it is certainly doable on that budget. Depending on how big and bad you go expect 440-500rwhp w/ all the boltons.
So much depends if you are paying labor, because some shops will try and take you to the cleaners........
6K is too light for either these, save your shekels and do it right. Maybe gears, long tubes, the new Halltech intake and a tune would get you a good start with an extra 50 HP and have some change left to gas her up. I'm sitting on 15K and am not sure which way to go, heck I could apply my fund to an 08'! Besides you will find the Z06 is one heck of a performer right out of the box!
No reason to take apart a running motor (at least until you get a lot more money!).
It's the $2k for the hood that's a ball buster, but once you get past that, all is good.
2.Proven performanc plus Magnusson has a very good reputation and I got great support when I did my V.
3. Ease of install. (I did the V myself and I made a great deal with the seller of the maggie on the Z install included)
4. Price. You can get deals on maggies if you are willing to shop. My whole job was under $10k with a polished maggie (the only way to go).
5.It is one true "bolt on" performance mod.
( I will be checking my mail for my shill check from Magnuson)
LOL
