HELP - HID Bulb Install
Old Oct 31, 2007 | 07:25 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by jrprich
It is because the HID's pull so much less current than the regular bulbs
Wondering.......if the problems like lights refusing to go down are really caused by the low current draw..perhaps someone should try an inline resistor like many use with LEDs that strobe.......to "fool" the computer into thinking the HIDs are Halogens ?
Any thoughts on this?
jdmvette, you are our light expert........your thoughts ?
i haven't had any experience with this problem, because my lights have always popped up/down. the lights in my kit are also 35w so i'm assuming it's the way they are wired is how they are staying up.
i am not sure if this helps anyone with bulb HID kits, but this is how my wiring looks:
as you can see, the high beam (red/black wires) have a white wire that taps into the low beam wiring (@ white plug) which then runs to the ballast.
maybe you can try something similar?
Old Oct 31, 2007 | 07:36 PM
jrprich's Avatar
jrprich
Actually my kits are not showing any of these issues.
I was just musing on the issues others are having and I know you have a lot of experience with lighting.
And I recall reading many post about LEDs fooling the computers by their low current draw.......and this seems similar to what users are seeing with the HID kits.
Old Oct 31, 2007 | 11:45 PM
dataporter's Avatar
dataporter
Originally Posted by ~Maverick
It is because the HID's pull so much less current than the reguar bulbs
~Maverick
Originally Posted by sneakelman
Same thing happens to mine. It's because of the low current pull on the bulbs. They draw so little that the module thinks there is a bulb out. Doesn't do it if you flip the switch to high beams BEFORE turning on the lights.
Well, I'm thinking that when you first turn HIDs on, they pull more amps than the stock ones to get them lit up, that is why some of these kits and threads etc talk about increasing the fuse size from 15a to 20a, and or having the engine running before turning them on. The ballast has to build up a very large electric charge to get the xenon excited and lit. Once they are lit they only pull a third or so of the power the stock ones require. It is similiar to fluorescent lights in the house or in an office, it takes a lot of power to start them, but once they are going, much less than incandescent lights. The suggestion to have the high beams on before turning the lights on so they pop up is a great idea. LEDs on the other hand do not have a ballast, they just take way less power from the get go, so I can see how the system might think a bulb was out. Thank you all for sharing your experiences, ideas and opinions! That is why this forum is so cool!
Old Oct 31, 2007 | 11:54 PM
dataporter's Avatar
dataporter
JDMVETTE do you have your HIDs in the High Beams or in the Low Beams or both?? Mine are 9006 replacements in the low beams.
Old Nov 1, 2007 | 12:04 AM
jdmvette's Avatar
jdmvette
Night Owl for life
mine are a different kit, projector HID in low, 65w halogen 9011 HIR1 in high. the kit is made by ACA.
Old Nov 1, 2007 | 12:09 AM
dataporter's Avatar
dataporter
Aaah, very nice!! The extra wire you referred to earlier is probably to keep the low beam HIDs on with the high beams... dp
Old Nov 1, 2007 | 12:16 AM
jdmvette's Avatar
jdmvette
Night Owl for life
that's true. it also could help with keeping the headlamps closed when you hit the switch...i don't know.
Old Nov 1, 2007 | 12:27 AM
dataporter's Avatar
dataporter
I have no trouble with them closing! It seems like every other time I turn them on, the lights come on BUT they don't pop up. I have to turn them off, then right back on and up they come.
Old Nov 1, 2007 | 12:31 AM
jrprich's Avatar
jrprich
Sorry to appear dense, but it is kinda hard to see, does this white wire run from the hot lead on the low beam HID bulb to the hot lead on the halogen high beam?
But if the white is just a jumper between the low and high hot wires that would turn the high beams on with the lows and vice versa..........so that doesn't seem likely
Old Nov 1, 2007 | 12:43 AM
jdmvette's Avatar
jdmvette
Night Owl for life
it looks like the white wire taps into the red high beam wire at the bulb, but i'm not sure which wire it taps into at the low beam without going back in there.
i'll check it out next time i'm in there.
Old Aug 11, 2008 | 05:09 PM
Black Out's Avatar
Black Out
Old thread but just curious if someone has found the fix after installing HID's and their headlights won't pop up the first couple of tries. I've been doing a lot of searching and I'm wondering if I do the small 194 bulb install on my headlight wiring harness if it will in fact allow my car to notice more of a draw from the headlights and allow them to pop up everytime I turn them on.
