LS1 to LS6 ?
Old Oct 30, 2007 | 03:48 PM
JUS 1 MO's Avatar
JUS 1 MO
Default LS1 to LS6 ?
Would there be any advantage to changing the intake, MAF, and possibly the throttle body from existing LS1 to a LS6 setup? The motor is stock except for Vararam and smooth inlet pipe, also Corsa pace car exhaust. If any advantage, how much, and is it worth the trouble and expense?
Old Oct 30, 2007 | 04:09 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Your 2003 came stock with the identical intake manifold, MAF sensor and throttle body as the LS6, so no.
Old Oct 30, 2007 | 04:12 PM
02MillenniumVette's Avatar
02MillenniumVette
Old Oct 30, 2007 | 04:27 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
The only difference is the heads and cam. Go for it.
Old Oct 30, 2007 | 08:37 PM
DefenderC5's Avatar
DefenderC5
You have an 03, you already have them.
Old Oct 31, 2007 | 11:24 AM
JUS 1 MO's Avatar
JUS 1 MO
Thanks... I am learning alot from you guys.........
To LS1 to LS6 ?
