Tire installation
Old Oct 30, 2007 | 08:30 PM
mike348's Avatar
mike348
Default Tire installation
For the people that buy tires mail order what are you paying to have run flats changed out. I called an installer and was told $269 for 4 tires.
Old Oct 30, 2007 | 08:36 PM
Bob CTS's Avatar
Bob CTS
Holy crap is that balanced?
I took a friends C5 w/ sensors to a tire shop, and he did them for $15/each and that included sticky weights. I knew the owner well but normal price is $25/each for carry in and not on the car.
Old Oct 30, 2007 | 08:39 PM
mike348's Avatar
mike348
Yes thats for balance too.
Old Oct 30, 2007 | 09:33 PM
djengr's Avatar
djengr
Sounds a little steep. I have changed from run flats to non-run flats, got balanced and the road force balance for $20 each. I brought the wheels and tires to the installer. I would not think run flats would be any higher. (Maybe a little higher, but not $65 each)
Good luck
Old Oct 30, 2007 | 09:49 PM
CHUXDRM's Avatar
CHUXDRM
That's way too steep! Was that an "installer" recommended by the tire seller? Go to Tirerack website, check for their recommended installers in your area.
I had mine installed for $62.00, that's tires installed on new rims, and road force balanced with sticky weights. I took them the tires and wheels. I thought I got by pretty cheap!
Yours might be alittle higher, because you're having a set of runflats removed, then a set mounted, right? Need to consider that , too.
Old Oct 30, 2007 | 09:50 PM
LTCHAPPA's Avatar
LTCHAPPA
$120.oo four tires,mounted,balanced,installed .Runflats
Old Oct 31, 2007 | 12:47 AM
04cad's Avatar
04cad
St. Jude Donor '07-'08
I had my four, "new" bought from CF, runflats installed at Tire Barn for $100.00 including balancing. Only place nearby that could do runflats. They took good care of the wheels and tires and made sure they were installed the right direction
Old Oct 31, 2007 | 05:31 AM
jpc0011's Avatar
jpc0011
I paid 90.00 to mount, roadforce balance and add new sensors.
Old Oct 31, 2007 | 07:40 AM
jughead1's Avatar
jughead1
From: Assault is a behavior, not a device! Cypress TX
St. Jude Donor '11
I think you're getting ripped if you pay that. Figure 20...maybe 30 bucks a wheel...mounted and balanced.
Old Oct 31, 2007 | 08:45 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I bought 4 new wheels and paid 100 to have the tires removed and reinstalled, balanced and the TPS moved also and installed back on the car.
Old Oct 31, 2007 | 04:47 PM
bighank's Avatar
bighank
Default $90 at Cheyv stealership
Road force balanced and disposal of old tires. $70 for demount, mount and balance and $5 for eash tire disposal.
Call around. Was cheaper than Tirerack or Discounttiredirect installers. BIGHANK
Old Oct 31, 2007 | 05:03 PM
mike348's Avatar
mike348
Thanks for the replies.
Old Oct 31, 2007 | 06:12 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
Cruise-In IX Veteran
BEND OVER
Old Oct 31, 2007 | 06:25 PM
OGC5's Avatar
OGC5
Default The going Rate-Rip off Corvette Tax
Just did the same,$130.00 w/Tax and they Hand Torqued the wheels!
OGC5
Old Oct 31, 2007 | 06:30 PM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by J.P.M.
BEND OVER
No kidding.
To Tire installation
