climate control panel
Old Oct 31, 2007 | 10:11 AM
stendahl's Avatar
stendahl
Cruising
Default climate control panel
As noted in July Road & Track, the climate control panel on c5's tend to fail - mine has. Is this a do-it-yourself job? Any suggestions?
Old Oct 31, 2007 | 10:15 AM
Bob CTS's Avatar
Bob CTS
Contact David Ruberg, he can fix it for $60, just had mine done last month. Fixes them the same day he gets them with a 5 year warranty.
Sent his email through PM
Old Oct 31, 2007 | 10:23 AM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
if your display is dim you can do it yourself in 30 minutes. thats is what I did.
Read this thread
http://forums.corvetteforum.com/show....php?t=1316227
Old Oct 31, 2007 | 12:20 PM
rws.1's Avatar
rws.1
David Ruberg = CF id mandigital = digitalguy_1@charter.net
Old Oct 31, 2007 | 04:14 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Common problem, Gm still has not fixed it. My 07 G6's lights are already going out.
Old Oct 31, 2007 | 04:20 PM
ALVETTE00's Avatar
ALVETTE00
I did mine myself.
Quick and easy. There are instructions on the main page for changing the speedo bezels. You can use those up to the part where they start removing the speedo area.
Old Oct 31, 2007 | 07:41 PM
SinghZvette's Avatar
SinghZvette
I would definitely recommend doing it yourself using the instructions posted, worked for me and I am a noob when it comes to work on my C5. Just a heads-up, take your time doing the work and make sure you do not touch the soldering iron on the chips for more than a second, the old solder will come off and the chips will move out of place, causing more grief than you want. Good luck
To climate control panel
