possibly bigger problems
Old Nov 1, 2007 | 04:35 PM
Sizzle's Avatar
Sizzle
Navigator
Default possibly bigger problems
My traction control needs service, the heater control light does not work, could these be expensive? But the car has been lowered.
Old Nov 1, 2007 | 04:44 PM
mcgilles's Avatar
mcgilles
if you are receiving traction control, ABS, or active handing messages on your DIC you have an EBCTM problem, very common. search for EBCTM or absfixer and you'll find everything you need to know!
if the heater control light you are talking about is the LCD screen which shows up very dim so you can barely read it at night, that is another very common problem. its pretty easy to fix if you have basic electrical skills. lots of info here!
the car being lowered shouldn't affect either
Old Nov 1, 2007 | 05:06 PM
Sizzle's Avatar
Sizzle
Navigator
Thanks! This gives me something to do in up coming winter months here in Alberta. I just want my new baby to run great with no problems.
Old Nov 1, 2007 | 05:16 PM
Sizzle's Avatar
Sizzle
Navigator
Default How to
what kind of electrical skills do I need? And how to apply these skills.
Old Nov 1, 2007 | 06:05 PM
Bill Dearborn's Avatar
Bill Dearborn
First run the On Board Diagnostics and find out what codes are showing. Just sending an EBCM unit off to ABSfixer isn't always the solution. What year car do you have? If it is a 2000 or earlier car does it have the JL4 option (Active Handling).
Bill
Old Nov 1, 2007 | 09:11 PM
cruisemon's Avatar
cruisemon
If you have a dealer do the EBCTM, plan on closer to $3000 than $2000. The heater/panel issue can turn into another $500 to $1000.
If you don't have the Helm manuals for your car, be sure you get them before you start pulling off parts.
Charlie
Old Nov 1, 2007 | 11:02 PM
SinghZvette's Avatar
SinghZvette
A used hvac display will cost you about $150 and it is real easy to change. As for fixing the LCD display, I followed the instructions on the below link. The electrical skill you need is to be able to solder a few chips that control the display .. very easy, I never held a solder iron in my life and was able to do it, carefully read and follow the instructions, word of caution: do not touch the old soldering joints more than a second, this will dislodge the chips and move them around causing more problems. Here's the instructions ..
http://forums.corvetteforum.com/show...ht=dim+display
To possibly bigger problems
