pumping the gas....
Old Nov 5, 2007 | 07:08 PM
jman1's Avatar
jman1
Default pumping the gas....
having issues starting my car.... only when it cold.... seems like it wont start unless i pump the gas...but it's EFI right? that makes no sense.....it'll start right up when its warm.. only in the mornings it gives me trouble...
Old Nov 5, 2007 | 07:10 PM
mcgilles's Avatar
mcgilles
how's your battery? batteries put out fewer amps when cold, and the more viscus oil requires more starter power to get the engine running. does it seem like the starter is struggling to rotate the motor or does it seem like its not getting fuel?
Old Nov 5, 2007 | 07:14 PM
jman1's Avatar
jman1
it turns over fine.....the battery is strong...does pressing the petal all the way down reset anything?..... it really seems like that helps..
Old Nov 5, 2007 | 07:46 PM
LoneStarFRC's Avatar
LoneStarFRC
Check your fuel pressure with the key on (engine not running). It should be going up to 58 lbs (+/-) and STAY there.
Old Nov 5, 2007 | 08:35 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its an electronic drive by wire throttle. You can pump the gas all you wish and it won't do a thing when the engine isn't running. However...if the throttle itself has a problem then you might be making it work. If you feel the throttle really is causing a difference, then replace it.
To pumping the gas....
