pass-key problems
Old Nov 5, 2007 | 08:57 PM
jbear's Avatar
jbear
3rd Gear
Default pass-key problems
Hi every one this is my first time asking a question, i am having problems with my pass-key ,i only have one key and it doesnt work any more. I have done everything in the owners manual ,I had the key checked at local chevy dealer they said its ok ,am geting new key made tommorow if that doesnt work then what ? thanks for any help
Old Nov 5, 2007 | 09:01 PM
Bill Dearborn's Avatar
Bill Dearborn
What are your symptoms and what codes are seeing on the DIC? To read codes turn key to ON without engine running then press and hold options while pushing the fuel button 4 times.
Bill
Old Nov 5, 2007 | 09:35 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Codes? Have you tried cleaning the pellet?
Old Nov 5, 2007 | 10:24 PM
jbear's Avatar
jbear
3rd Gear
will do codes tommorow , how should iclean pellet ? Thanks
Old Nov 6, 2007 | 12:17 AM
Bill Dearborn
You can use some contact cleaner. It is an electrical part. Can also use contact cleaner to clean the contacts inside the lock cylinder.
Bill
To pass-key problems
