Intermittent Starter problem: opinions please
Old Nov 5, 2007 | 11:37 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Default Intermittent Starter problem: opinions please
I'm posting this for a friend who doesn't frequent our beloved forum.
He has a 2000 MN6 coupe that is having intermittent starter failure.
Turns the key, gauges sweep, everything is powered up, fuel pump runs, but the starter doesn't do a thing.
He can bump start it.
The ignition switch has been replaced before.
It may be coincidence, but he says this began happening only after he had a dealership perform the column lock recall work (don't know how long ago that was done).
Doing a search, some similar posts have suggested...
New ignition switch
New battery
Clutch disengage switch
TDR relay - whatever that is
and of course, checking what codes may be present.
Anybody had the same symptoms and what was your fix???
Old Nov 6, 2007 | 08:06 AM
stormrider's Avatar
stormrider
I had the exact same symptoms last Fall, it was the starter going bad.
Old Nov 6, 2007 | 09:29 AM
lil vette's Avatar
lil vette
To Intermittent Starter problem: opinions please
