[Z06] Torque Management/Power robbing feature...
Old Nov 18, 2001 | 10:20 PM
WA 2 FST's Avatar
WA 2 FST
Default Torque Management/Power robbing feature...
Any of you run into this "monster" that lurks inside your PCM? I've read on Z06forum that the PCM can intermittently cut power when it senses "abuse"
during high rpm upshifts, downshifts, etc.
I am really just most concerned as to how often this might be occuring for some of you...especially those who race at the track (drag or open road). To me this is a bogus feature. That's what they make rev-limiters for.
I will say that if mine does this during "spirited" driving (and I don't abuse cars...I've owned, and do own, cars with more power than the Z and I've never busted a trans) it will be on the auction block.
Any more info would be appreciated.
Old Nov 19, 2001 | 07:00 PM
Keystone's Avatar
Keystone
Default Re: Torque Management/Power robbing feature... (WA 2 FST)
Can you post a link to the source thread, please? I'm interested in reading up on this.
Thanks,
Scott
Old Nov 19, 2001 | 09:17 PM
trumper Z06's Avatar
trumper Z06
Default Re: Torque Management/Power robbing feature... (Keystone)
:rolleyes: THis "feature" must only be on the 2002 model :(
Also appears the skid pad performance is down too........ .98 G vs. 1.01 for 2001's........but the 2002 Z06 rides smoother :nonod:
Thank gosh the "General's" watching out for us
Old Nov 19, 2001 | 10:17 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: Torque Management/Power robbing feature... (trumper Z06)
Nope, it's also on the '01's.........................as it happened to me, right after the 500 mile break in.....
Felt like you turned the ignition OFF.
Skid pad #'s down, because of the softer shock valving.....for better cornering & ride, but at the expense of launch, and wheel hop............
Old Nov 21, 2001 | 12:19 AM
ZO6LS6's Avatar
ZO6LS6
Wes...........bummer.........dead thred................had hoped we'd get LOT's of info........sorry. :(
Old Nov 21, 2001 | 02:25 AM
Power Shifter's Avatar
Power Shifter
Default Re: Torque Management/Power robbing feature... (ZO6LS6)
Sounds like your talking about "Power Hop Algorithm" with can engage even if T/C is turned off on the 02 cars. Reportedly it will reduce spark and or fuel if it sences axel hop on hard launch. Very good article by Hib Halverson in Jan 02 issue of GM High-Tech Performance is the source of this imfo. Ric
[Modified by Power Shifter, 12:28 AM 11/21/2001]
Old Nov 21, 2001 | 10:21 AM
ZO6LS6's Avatar
ZO6LS6
Default Re: Torque Management/Power robbing feature... (Power Shifter)
PS, seen that article.......what we are discussing seems to be different........
The condition above, feels like your engine is TURNED off.......it's that radical.......and @ 6000-6300rpm's, that sudden a cutoff is bad news on the senses....not to mention what it does to the perfomance.......
Old Nov 21, 2001 | 04:56 PM
2002EBZ06's Avatar
2002EBZ06
Wes,
I have not experience the "Torque Management/Power robbing " feature mentioned on z06vette.com. I'm not going to say its not there, but I just haven't experienced it. I have autox'ed, drag raced, hit the rev limiter, and showed off spinning the tires while getting sideways on the streets in my Z06 with no power loss except for the couple of times my traction control was on and the rear tires started to spin. I wouldn't worry about this too much. BTW, I'm not the average vette owner at 28 yrs old. I will push the limit of the car, well almost. :)
[Modified by 2002EBZ06, 4:05 PM 11/21/2001]
Old Nov 21, 2001 | 05:11 PM
Ranger's Avatar
Ranger
I've never run into this "feature" on my '01. While I've never missed a shift, I have run the car to redline a few times ;) and never encoutered the phenomenon. :confused:
Ranger
Old Nov 22, 2001 | 12:56 AM
Z06inator's Avatar
Z06inator
Wonder which one comes off a corner better?
Old Nov 22, 2001 | 01:23 AM
ZO6LS6's Avatar
ZO6LS6
Default Re: Torque Management/Power robbing feature... (BrianK)
Brian, the '02 does..........it is not as choppy a ride to hear the guru's tell it........at least that's what Hib said..............
But, the '01's have an advantage IN the straight line runs..........
To Torque Management/Power robbing feature...
