Rubbing Noise
Old Nov 7, 2007 | 11:20 PM
johnathanrn's Avatar
johnathanrn
Default Rubbing Noise
hello again everyone. heres the problem... when i put the car into reverse it sounds like the passanger rear tire is rubbing against something. the sound is not constant when i am reversing. Its as if there is a spot on the tire and everytime the tire rolls on that spot i hear that rubbing kinda sound. any ideas?
Old Nov 8, 2007 | 09:20 PM
rob-cyn's Avatar
rob-cyn
Maybe the Hand brake is not releasing all the way ? I know mine is hung up a little but I will wait to fix it when I put my drilled rotors on.
Old Nov 8, 2007 | 09:28 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
Wouldnt have C6 wheels would you??
Also fill out your profile!! Your not a rookie anymore!
Old Nov 8, 2007 | 10:39 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
I have the same thing happening on my stock 1999 coupe. No scrapes on the tires. It happens sometimes with sharp turns at slow speeds as well.
Old Nov 8, 2007 | 10:45 PM
rc69wc's Avatar
rc69wc
when i put my new slotted and drilled rotors on my e brake shoes were hung up i just sprayed the piston with pb blaster and pulled the handle a couple of times and walah.
now i use my e brake quite often to prevent it from happening again
Old Nov 8, 2007 | 10:46 PM
rc69wc's Avatar
rc69wc
have you checked the bearing hub assembly
that sounds like a possibilty
good luck
To Rubbing Noise
