I walk up to my car every morning afternoon etc..
The keyless doesnt work...
- i have reprogrammed the keyless fob many times
- replaced the battery with a new battery
the only thing that works is when i hold the unlock and lock button for the 7 second period it honks and i can open the doors... But, I've had to do this every morning and every afternoon etc...
It works for a little while but if i wait around 30 minutes or so then it forgets the keyless or something...
just searched for a bit, figured out that i probably need a new fob... =(... i have an extra one somewhere around here ill have to see if it holds the code...
thats what I did and everything is perfect now...it was just worn out.
Same thing happened to my 2000 and I took it to the dealer, they checked everything including the receiver in the car. I needed a new fob. I replaced it and haven't had problems with it since.
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I just bought a new FOB. Had the car tuned after headers, etc. install. FOB didn't work! Lock and unlock 7 seconds and car unlocked but the next time no. Repeated 7 sec and reached in through open window and unlocked it by door button with key in and no more problems. Someone should write a book about ths kinda stuff! Oops, they did, Corvette Forum.com!
This happened to mine, fob would work for one day then nothing. I then went to the owners manual and followed the procedure for a new fob (using the old fob) and it has been fine ever since. Try it out, much cheaper than a new fob.
Jeremy
The circuit board inside the remote probably has a broken or cold solder joint. On mine, I have seen it on the chip itself and other components close to the edge of the circuit board. Reflowing the solder joints worked for me.
Help! =(
mine did something similiar. sometime it worked and sometimes it didnt. i opened my up and noticed there was a broken solder. solder it back together and works fine now. the fobs are a little fragile. simply dropping the fob/keys, tossing them on the counter etc.. can cause the solder points to break. take a look inside the fob you'll probably discover one broken.
