Wearing inside front tires
Old Nov 11, 2007 | 11:01 AM
harrell3us's Avatar
harrell3us
Default Wearing inside front tires
I am on my third set of tires. I have had 2 front-end alignments. Nothing is helping. My front tires keep wearing on the inside about 2 inches. I have factory rims and Goodyear run-flats factory. Any suggestions on what my problem could be?
Old Nov 11, 2007 | 11:10 AM
vetter79's Avatar
vetter79
Same alignment shop? If so, change. Sounds like the castor/chamber is still off.
Good luck!
Also how many miles -prehaps a shock prob?
Old Nov 11, 2007 | 11:28 AM
jrose7004's Avatar
jrose7004
It's kind of the nature of the beast!
Old Nov 11, 2007 | 11:46 AM
jss812's Avatar
jss812
You need to corner faster.
On a more serious note, you might have the alignment shop go to the more conservative end of the alignment specs. They may be checking it and its within specs but on the more aggressive end (more negative camber) and not changing it.
I would think that if you told them what your problem is, they would set more positive. After giving it some thought, if I were them, I would not deviate from GM recommendations due to liability issues but they can certainly take it to the edge.
I've been thinking of having my front end alignment set less aggressive also. The roads here in Texas are really long and really straight. My front tires wear the inside edges also but doesn't sound like its as bad as yours.
Old Nov 11, 2007 | 12:07 PM
fixvet's Avatar
fixvet
I told my alignment guy that I wanted Zero camber. Did it and no wearing like that since. FYI....I'm not an autoX'er etc, but a long distance GT cruiser. I've got 30K on my tires and they look almost like new.
Old Nov 11, 2007 | 03:18 PM
harrell3us's Avatar
harrell3us
Thanks for the suggestions. I will check out the camber.
Old Nov 11, 2007 | 07:00 PM
Oldvetter's Avatar
Oldvetter
This is normal wear if you do more straight ahead higway driving instead of cornering. Happened to mine, but I still get 55,000 miles from front tires!
Old Nov 11, 2007 | 08:07 PM
PaulWall's Avatar
PaulWall
I agree its one of the perks to owning a vette.
To Wearing inside front tires
