damper pulley
Old Nov 11, 2007 | 05:45 PM
mgray's Avatar
mgray
2nd Gear
Default damper pulley
Why is my damper pulley out of alignment with all other pulleys by moving about one-quarter inch towards the engine. Any input will be appreciated.
Old Nov 11, 2007 | 08:48 PM
diyguy's Avatar
diyguy
Dont know why they do it. Mine did and it started to make that infamous bird chirp no matter what I did. Stealership worked on it 3 times before they had to R&R the harmonic balancer.
Good thing I had GMPP at the time. This is not a fun or cheap fix.
Good Luck --->
Old Nov 11, 2007 | 09:14 PM
mgray's Avatar
mgray
2nd Gear
thank you, I had a tech tell me today he felt that it is a worn thrust bearing which I just cannot believe!!
To damper pulley
