Running without TPS
Old Nov 13, 2007 | 07:56 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Running without TPS
Wondering how many are running without TPS and Runcraps.
If so how often do you check your pressure.
The Pup
Old Nov 13, 2007 | 08:32 AM
You would check the tire pressure just like any other car - with a tire gauge. But, why run without the TPS - it is a very good safety feature - and works just fine with runflats or non-runflats.
Old Nov 13, 2007 | 08:36 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
No TPMS in my 99 going on 4 years...check pressures weekly or bi-weekly at worst....
Old Nov 13, 2007 | 08:44 AM
Allzwell's Avatar
Allzwell
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Been running non-runflats for years WITH tire pressure sensors. I don't know why you would not want them.
Old Nov 13, 2007 | 09:10 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I have been running without them for 2 years and no issues at all
Old Nov 13, 2007 | 09:32 AM
Whiteonrice's Avatar
Whiteonrice
I don't have them. I check tire pressure old way.
Rick
Old Nov 13, 2007 | 04:35 PM
DefenderC5's Avatar
DefenderC5
Same here.
Old Nov 13, 2007 | 04:45 PM
OutKlast's Avatar
OutKlast
I don't have TPS or runflats. On my next set of wheels I'd like to try to get ahold of some TPS though. Why not? Not much weight and good to know info.
Old Nov 13, 2007 | 08:48 PM
TEXHAWK0's Avatar
TEXHAWK0
Even GM states that having TPS is not a substitute for regularly checking tire pressures with a pressure gage. I check mine in the garage while they are cold every week or so. I make a visual check of my non-run flat tires almost everytime I drive it.
To Running without TPS
