Mohawk Scissor Lifts???
Old Nov 13, 2007 | 11:58 AM
Crusher's Avatar
Crusher
Just an Ole Surfer Boy
NCM Ambassador
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VII Veteran
St. Jude Donor '04-'05-'08-'09-'10-'13-'14
Default Mohawk Scissor Lifts???
Have this in the detail section but not much help....
Anyone have either Mohawk Scissor lift? Interested in what you think of it and what you paid for it. Looking to use it more for detailing then under body work.........
http://www.mohawklifts.com/consumer/scissor.php
Old Nov 13, 2007 | 12:31 PM
BATM4N's Avatar
BATM4N
LOS ANGELES PI has one Or at least one that is just like it.
Old Nov 13, 2007 | 10:12 PM
CF6873's Avatar
CF6873
I have a Bend-Pak scissors lift and I love it. I don't have ceiling height for a twin post so this is the next best thing. It is great for tire and brake work as well as detailing. I can sit on my creeper stool and wipe the tar off of the sides.
Old Nov 13, 2007 | 10:38 PM
last toy's Avatar
last toy
I have a Gegesmith unit , the only problem with it is that the lift arms are to short to lift it where you would use lifting pucks. Had to make my own longer lift arms. Works great for detailing, oil changes etc.
Old Nov 14, 2007 | 07:59 AM
fun_n_sun's Avatar
fun_n_sun
Is this the one you have???
https://www.autobodytoolmart.com/p-14043-17447.aspx
Old Nov 15, 2007 | 06:41 PM
CF6873's Avatar
CF6873
I have this one. It comes with 3 sizes of arm extensions and it can be moved from one bay to another if necessary.
http://www.bendpak.com/cart_product_...=260&cat_id=49
Old Nov 15, 2007 | 06:45 PM
34RedRage's Avatar
34RedRage
i have a double park 4 post with a 10' 3" ceiling. i can lift any vette to its max with that ceiling. my cost 3 years ago was $2800.00 shipped to my doorstep....
Old Nov 26, 2007 | 09:37 PM
HIRISC's Avatar
HIRISC
St. Jude Donor '06
Mohawk makes a very good scissor lift. Good mechanical safety plus the unique advantage of hydraulic velocity fuses.
None of the imports offer VFuses - and neither does Bend-Pak for that matter.
I think you'll find that Mohawk scissor lifts command a premium price > $2,000 landed.
Nobody near me sold Mohawk (or Norco) when I was looking, so I selected a Bend-Pak MD-6XP - love it.
All three are vastly superior to the cheap knock-offs.
More on the Bend-Pak: http://forums.corvetteforum.com/show....php?t=1483905
$0.02 deposited
Chris
Old Nov 26, 2007 | 10:05 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
I agree with the quality of Mohawk lifts,and the price.They are the HRE of the lift co's.
The lift LOSANGELESPI has is the bendpak spx7.It is the bigger brother of the 6xp.IMO, this is the best lift out there for the home garage,if you have a 9ft. ceiling or better( 10 is optimum)
It will also cost about twice as much as the 6xp,which does make the 6xp a very good bargain...
But the spx7 IS the bomb!No posts taking up space,no making full ramps to get it over the lift,you just park on it when not in use,complete access to the entire undercarriage of your car.
The only limitation I have found is this,don't try to put rocker rails on using it
Old Nov 26, 2007 | 10:18 PM
HIRISC's Avatar
HIRISC
St. Jude Donor '06
These are really great - there are a few guys on the CF with them.
The bottom is wide-open vs 'some' limitation with the mid-rise scissor lifts.
One thing that didn't work for me was that the SP-X7 needs to be bolted to the floor. My garage layout didn't favor that, but if it did, I might have gone that way.
It looks like Bend-Pak is now offering a similar 'full-scissor' with a 4500lb capacity (vs 7K lbs for the SP-X7). Might be a good way to save some $$.
http://www.bendpak.com/cart_product_...=263&cat_id=49
Old Nov 27, 2007 | 05:01 PM
LOS ANGELES PI's Avatar
LOS ANGELES PI
Youll be hitting your head and scraping your back on those ramps that swing up with the lift.
Dont let the warnings about concrete thickness scare you off, most Garage floors are 3 1/2 thick and will be fine.
That lift is so damn heavy you almost dont even need to bolt them in. They come in one solid, 2600 poound unit.
Good luck on your lift !
To Mohawk Scissor Lifts???
