U1160-causing my problems?
Old Nov 13, 2007 | 02:39 PM
Ilovechevymusclecars's Avatar
Default U1160-causing my problems?
The only current code is U1160, which is the Loss of Communications with LDCM.
My driver's side window isn't working, and I am wondering if this is the problem. Is it a bad relay, or something else?
When I applied pressure with my feet to the area near the passenger fuse box, the window temporarily worked. What electronics on the passanger side should I check?
