Removing and installing battery
Old Nov 13, 2007 | 03:52 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
Default Removing and installing battery
I know I've seen the sequence but I cant find it. Which post do you disconnect first? Pos or Neg? when removing the old battery?
Old Nov 13, 2007 | 03:56 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Neg
Old Nov 13, 2007 | 04:19 PM
Bills03Coupe's Avatar
Bills03Coupe
Negative, first off, last on.
Old Nov 13, 2007 | 04:24 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
thanks
Old Nov 13, 2007 | 04:42 PM
TraceZ's Avatar
TraceZ
If both posts are connected and you put a wrench on the + post you create a hazard. If the + wrench touches anything metal as you are removing the post it will short out + to - because all metal in the car is ground -.
If both posts are connected and you put a wrench on the - post you do not create a hazard. If the - wrench touches anything metal as you are removing the post it will not do anything because the wrench is - and the metal in the car is also ground -.
Once the - post is disconnected, you can wrench on the + post without creating a hazard because there is no chance of it shorting out on the ground -. Even if you were to have the + wrench on the terminal and rest it hard agianst a metal component nothing would happen because the electricity would have no way to get back to the - terminal on the battery.
I hope that makes it clear as mud... LOL.
Basically you do not ever want to place a wrench on the + terminal if the - terminal is connected.
Old Nov 13, 2007 | 06:44 PM
jochumr's Avatar
jochumr
St. Jude Donor '10
I work with rocket scientists .. makes perfect sense.
Old Nov 13, 2007 | 10:56 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Connect a battery jump-pak to the cables and you won't have to redo and memory sets.
Old Nov 13, 2007 | 11:33 PM
TraceZ's Avatar
TraceZ
I've seen those that plug into the cigarette lighter. I don't know how long they last, though. Especially in a C5 with all the electronic systems drawing on it.
Old Nov 14, 2007 | 03:14 AM
Old Nov 14, 2007 | 04:42 AM
Kamil D.'s Avatar
Kamil D.
Originally Posted by JDs00PewterCoupe
sorry just making sure, so when connecting the battery positive firs right??
Old Nov 14, 2007 | 05:34 AM
Junkman2008's Avatar
Junkman2008
You know, with an electronics's degree I never knew this but with your explanation, it makes perfectly good sense! Now I'll have to file that away with, "righty tighty, lefty loosey..."
Old Nov 14, 2007 | 05:36 AM
Junkman2008
Negative off first, negative on last.
Old Nov 14, 2007 | 06:26 AM
Kamil D.'s Avatar
Kamil D.
Old Nov 14, 2007 | 10:39 AM
hotwheels57's Avatar
hotwheels57
They use a 9v battery...good for a few hours at most with the draw of the electronics. I use one when I'm doing work expected to last 2-3 hours with the battery disconnected.
Old Nov 14, 2007 | 01:06 PM
peebee_c5's Avatar
peebee_c5
If the + wrench touches anything metal as you are removing the post....
Metal?!? What metal?!? Good luck finding a ground anywhere in that car!!! ;-P
Old Nov 14, 2007 | 02:02 PM
TraceZ's Avatar
TraceZ
Ok, so it's a really long wrench!!
To Removing and installing battery
