need quick answer
Old Nov 16, 2007 | 12:31 PM
vinnyxgunz's Avatar
vinnyxgunz
Default need quick answer
how do you install the front license plate filler... it took me forever to find a used one and i want to install it right... thanks in advanced
Old Nov 16, 2007 | 12:39 PM
78-Bandit's Avatar
78-Bandit
Active Streak: 90 Days
there are screws that go in under the plate. Basically, you tilt the top in, then push the bottom flush. You have to squeeze your screwdriver in between the bottom of the filler plate, and the bumper (from the outside). Use a round screwdriver, so you don't chip the paint on the filler or bumper.
Old Nov 16, 2007 | 12:49 PM
bucwheat's Avatar
bucwheat
Thats all there is to it, but Wrap tape around the screwdriver shaft.
To need quick answer
