Newcomer to C5 section needs Duh! help
Old Nov 17, 2007 | 07:44 AM
guppie's Avatar
guppie
St. Jude Donor '08
Default Newcomer to C5 section needs Duh! help
OK I know it don't take a rocket scientist but I just bought an 01 and the lamp under the hood doesn't work.
Before I break something how do you get the cover off to change the bulb? I know DUH!
Old Nov 17, 2007 | 07:45 AM
guppie's Avatar
guppie
St. Jude Donor '08
By the way looks like I'm going to have to change my avatar
Old Nov 17, 2007 | 08:12 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Before changing the bulb:
On the passenger side - in front of the radiator shroud, you will see the electrical wire from the hood - there is a connector if you follow the wire - make sure it is plugged in.
Many dealers/owners disconnect this connection if the hood is going to remain up for long periods (it is not necessary to do so since the light will turn off by itself after 15 minutes).
guppie's Avatar
guppie
St. Jude Donor '08
Never mind got it
Old Nov 17, 2007 | 08:37 AM
rws.1's Avatar
rws.1
you can buy the bulb anywhere the automotive lighting is sold...
Walmart is cheapest I have found for bulbs.
Old Nov 17, 2007 | 08:48 AM
guppie's Avatar
guppie
St. Jude Donor '08
I did see that it was unplugged but it still won't work after being plugged in, checked the bulb with a meter it's fine. everything else seemd to work so not sure about it being a fuse and according to the manual I don't know which one it is anyway.
Thanks for the response
Old Nov 17, 2007 | 08:52 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It is not uncommon. Many owners that attend shows unplug the light since they have their hood up so often at the show. As a result, the contacts in the plug socket get dirty. I would recommend some contact cleaner and a very small wire brush and I bet it will work just fine. When I bought my '97 I had the same problem and that did the trick. In absence of a wire brush you could try plugging and unplugging the light several times to clean off the connections.
Old Nov 17, 2007 | 08:54 AM
vettes4fun's Avatar
vettes4fun
Welcome to the C5 side
Old Nov 17, 2007 | 09:11 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
Try cleaning the contacts - since it was unplugged all sorts of corrosion/debris is probably present.
Old Nov 17, 2007 | 09:13 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Very common
Old Nov 17, 2007 | 09:16 AM
Bob CTS's Avatar
Bob CTS
And check for voltage at the connector with your meter. That will start narrowing down the possibilities.
Old Nov 17, 2007 | 10:20 AM
steve8's Avatar
steve8
I had a 78 L-82 silver anniversary edition. You are going to love the C5. Good luck.
Old Nov 17, 2007 | 10:53 AM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Hello and welcome
Old Nov 17, 2007 | 01:07 PM
WetteVette's Avatar
WetteVette
My car came without the bulb cover. Couldn't buy just the cover, so ended up buying the whole assemble from Gene Culley at gmpartshouse.com for around $20.
Old Nov 17, 2007 | 01:17 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome to C5.
My Dad always used to say "The only stupid question is the one you don't ask".
That's why the Forum is here .
Old Nov 17, 2007 | 01:23 PM
vetter79's Avatar
vetter79
Did you put the bulb in after the hood was opened for longer than 15 min.?
Old Nov 18, 2007 | 06:43 AM
guppie's Avatar
guppie
St. Jude Donor '08
Thanks for the Welcome to the C5 section, some of you I've met from time to time at the Dayton get togethers from the Great Lakes section.
Great people on the Corvette forum in all sections.
I had to leave yesterday so I didn't get to work on it anymore.
Planned on cleaning the contacts or terminals today and checking voltage to see if there's juice that far.
I could'nt find which fuse was linked to it but I did check the bulb and it's good
To Newcomer to C5 section needs Duh! help
Old Nov 18, 2007 | 06:47 AM
guppie's Avatar
guppie
St. Jude Donor '08
By the way I could'nt believe the difference just driving the C5 home
WOW! I know I'm going to love it. Can't even compare it to my C3 even though I dredded getting rid of it. The only I could say after driving a
C5 is BYE! BYE!
Old Nov 18, 2007 | 07:13 AM
Lord Vetter's Avatar
Lord Vetter
St. Jude Donor '09-'10-'11-'12-'13
Another thing to look at is...do the lights on your inside rearview mirror work also? The mirror lights and the underhood light are on the same circuit. If neither of them work, remove the floor mat on the passenger side, remove the fuse box lid you'll find there, then check to see if the 20A fuse in position 2 is still good. Had this same problem on my 04. Replaced the fuse and lights were back on.
Old Nov 18, 2007 | 07:48 PM
guppie's Avatar
guppie
St. Jude Donor '08
Those lights work, I can't find anything else not working
