Headlight Motor
Old Nov 19, 2007 | 04:42 PM
1320dance's Avatar
1320dance
Default Headlight Motor
How hard will it be to change my motor myself, 2000 Vette.
Thanks a lot
Old Nov 19, 2007 | 04:47 PM
Oldvetter's Avatar
Oldvetter
Pretty easy, search for headlight gear replacement. I think it is a sticky in TECH section. You may only need a gear.
Old Nov 19, 2007 | 05:08 PM
BosqueVette98's Avatar
BosqueVette98
I did mine one evening after work. Took me a couple hours following one of the write ups a forum member had posted. It's not too difficult, just take your time.
Old Nov 19, 2007 | 06:44 PM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Change just motor: 45 minutes or so
Change motor gear to brass: about an hour
Pretty easy fixes.
Why do you need to change the motor? What issues are you having with it?
Old Nov 20, 2007 | 05:06 PM
1320dance's Avatar
1320dance
Its not my motor, just needs a new gear. Dealer wanted to replace my motor but I will change it myself.
Old Nov 26, 2007 | 11:21 PM
SilverMN6's Avatar
SilverMN6
Local dealer wanted $650 parts and labor to replace motor, part was supposedly on back order nationally, and they wanted me to pay for the part in advance.
Checked with Mid America who had the part for $30. They also had instruction sheet on their website that you can print out.
Nowadays, I am only moderately mechanically inclined. After studying the mechanism for a bit, it took less than an hour start to finish.
Good luck.
P.S. I figured it was a no-lose situation, GM would only replace the whole motor and they can't get the part, and even if I totally messed it up, I would have shipped a box of parts to Mid America who would do a rebuild for around $175(I think).
Old Nov 27, 2007 | 12:20 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Thanks a lot
Here are a couple of good "how to" links:
http://forums.corvetteforum.com/show...headlight+gear
http://forums.corvetteforum.com/show....php?t=1767764
Old Nov 27, 2007 | 04:27 AM
Junkman2008's Avatar
Junkman2008
...and then there's mine...for dummies!
http://forums.corvetteforum.com/show....php?t=1823603
Old Nov 27, 2007 | 04:34 AM
vetter79's Avatar
vetter79
http://www.bfranker.badz28.com/headlightfix/index.htm
Old Nov 27, 2007 | 07:20 AM
Jet-Jock's Avatar
Jet-Jock
It probably takes about an hour to swap out the motors. I just bought a new one and replaced it. If you don't have huge hands, you can do the procedure with only removing the cover and the fascia. The FSM says to remove the lower panel and access it from underneath, nonsense it can be done from above as I mentioned.
To Headlight Motor
