Ratios??
Old Nov 20, 2007 | 12:51 AM
CharlieB1979's Avatar
CharlieB1979
Default Ratios??
I want to upgrade to a sick ratio..i'm talking 4.10...yes, that's sick and I can already see my MPG go straight into the sewer...but does that REALLY cost some $1,700?!!?
Someone lend an assist here....
Old Nov 20, 2007 | 10:45 AM
CharlieB1979
**Bump, bump!**
Guys, I can use your advice here
Old Nov 20, 2007 | 11:02 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Too many variables to answer your question. Are you doing the work, or having it done? New parts or used? Need more info.
Old Nov 20, 2007 | 11:27 AM
lil vette's Avatar
lil vette
Forum Vendor
http://www.dynotech-eng.com/dte_c5_diff.htm
Old Nov 20, 2007 | 02:34 PM
CharlieB1979
Hmmm...well i'm looking for new. I'll be doing the job myself actually. ...i'm seeing that the axle ratio options are expensive as hell!!
Old Nov 20, 2007 | 02:53 PM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Default Research 1st
Theres more to it than just numbers. What year, engine mods and trans do you have now? A 4:10 in a 6sp makes 1st gear almost useless but in an A4 its doable. Then theres the clutch/TQconverter. If you have an A4 with a 2:73 then you need an entire new pig. $2K is the ball park figure. Good luck, you may want to do some more home work, before starting this project, unless you've done them before.
Old Nov 20, 2007 | 03:13 PM
1998whitecoupe-a4's Avatar
1998whitecoupe-a4
$1700.00 sounds about right if it's brand new.
I paid $800.00 for a used 3.42 with less than a 1000 miles on it.
4.10's are hard to come by used.
Be prepared to invest in some sticky tires.
Good luck with the project though.
Old Nov 20, 2007 | 09:58 PM
c5streak's Avatar
c5streak
Had 4.10's in my last C5, a '99 Coupe, 6-spd. Acceleration was incredible, and still had amazing MPG even with about 410RWHP. I got around 26-28 hwy!
Old Nov 21, 2007 | 08:40 AM
kww's Avatar
kww
Had mine installed by ECS. Chris, Doug and his team. $1295 for the 4:10's. Had it done while I waited. I'm still getting between 25 and 26mpg and that's better than the wifes Honda CRV four banger. 75 mph 1895rpm. Wouln't recommend going that route with the A4 but the M6 seems right at home with the 4:10's-couldn't be happier.
Old Nov 21, 2007 | 08:51 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Our '04 has 4:10's. Also has LPE H/C. Kooks, Borlas, under- pulley - MN6.
RWHP = 440
My '99 has an LPE 427, Kooks, MN12 (Z06 tranny) Borlas.
RWHP = 539
Driving the '04 is much more 'exciting' = pulls through 1/2/3/4 like a ****.
The S/O (who has the '04) pulls me from a hole shot (even with 305's I cannot keep the wheels stuck to the pavement ).
For those who say 1st gear with 4:10 and a MN6 is useless - I challenge them to take a ride with the S/O
Old Nov 22, 2007 | 11:16 AM
CharlieB1979
Awesome stories
I am still looking for a black A4 97-04 (If anyone can help, please do!), and if I change the gear ratio to 4.10, i'm gonna get acceleration out the ying yang, however, my top end will drop like a rock and my gas mileage will be like 8MPG LOLOL
What's your take on that?
Old Nov 22, 2007 | 11:25 AM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by CharlieB1979
I want to upgrade to a sick ratio..i'm talking 4.10...yes, that's sick ...
No problem as long as that's what you want your C5 to turn into. The only drawback to those going to these "sick" ratios is the law of unintended consequences. But it looks like you know exactly where you want to end up... more power to ya'
In regrads to those saying "new"... Getrag never mfgrd C5 carriers with the 3.90 or 4.10 ratios. So, any "pumpkin" purchased with these ratios will have to of been a rebuilt variety. And not that this is bad or anything... just a data clarification.
as long as you can keep the tires from going-up-in-smoke...
Old Nov 22, 2007 | 01:24 PM
CharlieB1979
Oh you're right, you're right...4.10 ratio is insane anyway and a complete waste of time off the track...g'head, drive that in the snow LOLOL!! ^_^. Ultimately, i'm looking for a 3.10 variant or maybe, at the absolute highest 3.43...I can hold ground with those very well without sacrificing the fuel tank entirely.
Old Nov 22, 2007 | 01:37 PM
army2000's Avatar
army2000
St. Jude Donor '11
ZO6 3.42 is what you want...good luck.
To Ratios??
