help on servince traction control/abs
Old Nov 21, 2007 | 08:27 AM
mattkilla97whitec5's Avatar
mattkilla97whitec5
Default help on servince traction control/abs
it used to be every once and a while then it got more frequent then it stopped , but not everytime im in the car the service traction controll/abs comes on. i cleaned the 2 grounds in the engine very well today and then i started my car and turned the steering wheel all the way over both sides then it came on. i notice that it comes on when i use my steering wheel far either way, usually backing out of my narrow drivway. the only code that is current is it says 38 rtd no communication. what does that mean????? hope this doesnt cose too much, just spend $$$$ to rebuilt the tranny
Old Nov 21, 2007 | 08:33 AM
bucwheat's Avatar
bucwheat
had same problem,dis connected battery once to replace with a new one and the problem healed itself or reset maybe.
mattkilla97whitec5
so i figured it out that it means real time dampening but if there are no current codes for it what should i do??????
Old Nov 21, 2007 | 02:10 PM
C5-BRUCE's Avatar
C5-BRUCE
Default Bad Battery
Quite often this is caused by low battery voltage. Check out the battery before you do anything rash, like go to the dealer.
Old Nov 21, 2007 | 02:21 PM
darb21's Avatar
darb21
What is the actual code?
Old Nov 22, 2007 | 06:13 AM
mattkilla97whitec5
i dont have any current codes showing up only 38 rtd no comm. my battery is fine its pretty new- 4 months at most. and reading 12.5 volts.
Old Nov 22, 2007 | 06:59 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
Have you recently installed powder coated calipers? If so, you may need to remove some powder coating at the contact points.
To help on servince traction control/abs
