Any belt replacement write ups?
Old Feb 24, 2008 | 10:07 PM
00 Rooster's Avatar
00 Rooster
St. Jude Donor '08
Originally Posted by BIG ATLANTA
Another tip I always keep my old belts in one of the compartments. If your on a trip or a cruise and the belt breaks you've got a temporary replacement. I do this on all my vehicles and it has come in handy not for me but someone in our group
and because my dumb a$$ knew better, I will be digging my old one out of the garbage :o
Old Aug 23, 2008 | 12:11 PM
talbott69's Avatar
talbott69
1st Gear
This worked perfect and didn't take very long. I replaced with Goodyear Gatorback belts.
Old Aug 23, 2008 | 12:45 PM
KCvetteowner's Avatar
KCvetteowner
While you are working on your belts take about 5 minutes and inspect the electrical connector on the front of the ac compressor. I have had a belt destroy that connector on my Corvette and on a '95 Chevy Blazer. It's not a fun time when a $30 belt takes out a compressor!
Old Nov 8, 2009 | 10:07 PM
jww193's Avatar
jww193
Thanks all for the great writeup, replaced both belts and the write up and diagrams really helped. One thing the I did different was use a box wrench on the AC pulley tensioner. I have a 15mm where the box end ratchets (they are great) and it worked like a charm. BTW-whats with all the metrics sizes?
Old Nov 17, 2009 | 08:19 AM
vetdude's Avatar
vetdude
Taking the wife's '98 back to the service dept. for the 3rd time to fix the GD belt chirp!!! When the chirp first started about four months ago, had both belts replaced; started chirping again by the end of the day. Back to have both pulleys/tensioners replaced; started chirping again in a couple of weeks, combined with a noticeble smell of rubber coming from under the hood). After over $300 in parts/labor, what else could it be???? At wits end.
footnote: sprayed a little WD40 on the serpentine belt and the chirp goes away....for about 3 minutes!
