Wiper Motor or Module
Old Nov 25, 2007 | 02:24 PM
matt24's Avatar
matt24
Default Wiper Motor or Module
My Wipers only function on high and now they will not turn off. Would that be the motor/module or the wiper switch? Couldnt find a good answer searching. Ive already taken out the motor and I think I will try one from autozone soon unless its the switch. Thanks!
Old Nov 25, 2007 | 02:55 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Given your symptoms, my guess would be the stalk switch and not the motor.
Old Nov 25, 2007 | 05:10 PM
yardstick0802's Avatar
yardstick0802
Default Your Solution!
I posted a thread about a month or so ago. It is most likely the motor i had the same problem and tried the switch first and that wasnt it so i got the reman motor from advanced auto parts. The problem with mine was the udders under the motor where full of trash and the motors seal was bad so i took it apart and the motor was full of water and there is a circuit board inside of it. Solution replace the motor first or just take it apart and check it because once you buy a switch you cant return it at chevy. If it is the switch let me know i still have the one i bought i will sell it to you for half off.
To Wiper Motor or Module
