Did a Stupid Thing Changing Oil
#41
Drain+Refill and Forget!!!
My friend- Drain and forget it.
Refill will Mobil 1 Syn Oil.
The cost of Mobil 1 - versus your worries dictates you do this.
This my 2 cents.
BTW- I have been using Mobil 1 Syn engine oils in all my cars since 1988.
This my 2 cents.
#42
Change it in the spring, as many others have stated it wont hurt anything even if you didnt change it. But why change it now and then let it sit, then change it again in the spring
#43
C'mon - this your vette, your Baby. Drain it and start over - cheap insurance against anything bad happening.
Besides if you leave it, you're going to be in a constant worry that the motor is about to disentegrate at any second!
Lower your stress level - drain it...
Gordon
Gordon
#44
St. Jude Donor '09, '13, '15
Yeah...like said...run it just a bit to help clean out any sludge and then start over again with another oil change. Heck, maybe you just discovered some new oil performance tip!!
#45
Received 19,871 Likes
'20-'21-'22-'23-'24
Used to do that on engines with carbs. But if you are really worried about it, just drain it out and then fill with the right stuff.
