My baby has the HUD but it is very low when I sit back in the seat it is barely visible. Is there a way to adjust the unit to project it higher on the glass?
You can raise the seat, tilt the back forward or sit on a cushion. Unless the unit is loose internally, you don't have a manual adjustment. Just for reference, how tall are you? It's possible something has slipped inside. Do you have any contacts with a Vette with HUD that you can sit in to compare?
This happened to mine also. You have to remove the dash and then remove the HUD unit. After I disassembled the HUD I found that one of the plastic hinge pins had wore off. I drilled it out and put in a #2 wood screw. All is good now. It will take just about all day.
