Headlight vibration
Old Nov 29, 2007 | 03:44 PM
Ghostrdr53's Avatar
Ghostrdr53
3rd Gear
Default Headlight vibration
My left front light vibrates when up, other than that it works perfect, vibrates up and down about 1/4 inch, seams like there is some play at the pivots, car is an '03. Is there an adjustment or bushing issue I should be looking perform or replace? Thanks!!
Old Nov 29, 2007 | 06:19 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
First, check that the bulb is in properly and tight. If not, you may need to take off the doors and black surround piece and check out the plastic bushings and adjusters, good luck.
